跳转到主内容
加入维修社区 - 创建账户
HP 15-d076nr Wireless Card Replacement
你所需要的
  1. HP 15-d076nr Wireless Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Orient the laptop upside down so that the back of the laptop, where the battery is located, faces you.
    • Locate the left and right switches at the bottom of the laptop.
    询问修复机器人
    添加评论
  2. HP 15-d076nr Wireless Card Replacement: 步骤 2 中的图像 1,1
    • Move the right switch to the left so that the orange unlock symbol is showing.
    询问修复机器人
    添加评论
  3. HP 15-d076nr Wireless Card Replacement: 步骤 3 中的图像 1,1
    • Move the left switch to the right, covering the battery symbol, and hold.
    询问修复机器人
    添加评论
  4. HP 15-d076nr Wireless Card Replacement: 步骤 4 中的图像 1,1
    • While holding the left switch in place, slide the battery towards you and away from the laptop.
    询问修复机器人
    添加评论
  5. HP 15-d076nr Wireless Card Replacement, Wireless Card: 步骤 5 中的图像 1,1
    • Re-orient the laptop, so that the back of the laptop faces away from you.
    询问修复机器人
    添加评论
  6. HP 15-d076nr Wireless Card Replacement: 步骤 6 中的图像 1,1
    • Locate the small screw on the panel at the center of the laptop.
    • Loosen the small screw using a Philips # 1 screwdriver.
    • The screw does not come free from the panel. It only needs to be loosened enough so that the panel can be lifted/pried.
    询问修复机器人
    添加评论
  7. HP 15-d076nr Wireless Card Replacement: 步骤 7 中的图像 1,2 HP 15-d076nr Wireless Card Replacement: 步骤 7 中的图像 2,2
    • Carefully pry the middle panel up using a plastic spudger, or other prying tool .
    • Pull the panel away from the laptop and set it off to the side.
    询问修复机器人
    添加评论
  8. HP 15-d076nr Wireless Card Replacement: 步骤 8 中的图像 1,2 HP 15-d076nr Wireless Card Replacement: 步骤 8 中的图像 2,2
    • Gently wiggle and lift the black antenna wire away from the wireless card.
    • If there is also a white wire attached, both black and white wires will need to be removed from the wireless card.
    询问修复机器人
    添加评论
  9. HP 15-d076nr Wireless Card Replacement: 步骤 9 中的图像 1,3 HP 15-d076nr Wireless Card Replacement: 步骤 9 中的图像 2,3 HP 15-d076nr Wireless Card Replacement: 步骤 9 中的图像 3,3
    • Locate the Phillips 2.0x3.0mm screw on the upper left corner of the wireless card.
    • Carefully remove the 2.0x3.0mm screw using a Philips #0 screwdriver.
    询问修复机器人
    添加评论
  10. HP 15-d076nr Wireless Card Replacement: 步骤 10 中的图像 1,1
    • Slide the wireless card to the left to remove it from the socket.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 785
