跳转到主内容
加入维修社区 - 创建账户
HP 15-ay052nr Fan Replacement
你所需要的
    1. HP 15-ay052nr Fan Replacement, Battery: 步骤 1 中的图像 1,1
      • To protect the device and yourself, make sure your device is completely powered down before disassembling. Disconnect all external devices before starting any tear down process.
      • Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
      询问修复机器人
      添加评论
    2. HP 15-ay052nr Fan Replacement: 步骤 2 中的图像 1,1
      • Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
      • The sliders are located at the back of the device on the side where the display hinges are.
      • The slider closest to the optical drive (CD reader) clicks open but the opposite slider has a spring.
      询问修复机器人
      添加评论
    3. HP 15-ay052nr Fan Replacement: 步骤 3 中的图像 1,1
      • Pull the battery slightly up and out to remove.
      • If the battery doesn't pop out, the sliders weren't pushed in far enough. Push the sliders towards the center until the battery pops out.
      询问修复机器人
      添加评论
    1. HP 15-ay052nr Fan Replacement, Bottom Cover: 步骤 4 中的图像 1,1
      • Remove the rubber feet on the bottom of the device to access all the screws.
      • There are two rubber feet, one on each side of the battery compartment.
      询问修复机器人
      添加评论
    2. HP 15-ay052nr Fan Replacement: 步骤 5 中的图像 1,1
      • Unscrew the twelve 9 mm JIS #0 screws on the back of the device.
      • Gently remove the optical drive (CD reader) to more easily separate the base.
      询问修复机器人
      添加评论
    3. HP 15-ay052nr Fan Replacement: 步骤 6 中的图像 1,1
      • Unclip the keyboard surface from the base using an iFixit opening tool around the entire border.
      询问修复机器人
      添加评论
    4. HP 15-ay052nr Fan Replacement: 步骤 7 中的图像 1,1
      • Separate the base of the computer from the component assembly.
      • The optical drive can be placed in the base where it corresponds to prevent misplacing it.
      询问修复机器人
      添加评论
    1. HP 15-ay052nr Fan Replacement, Fan: 步骤 8 中的图像 1,1
      • Remove the two 6.5 mm JIS #0 screws holding the cooling fan to the base.
      • The base is the side by the heatsink, which is made of copper.
      询问修复机器人
      添加评论
    2. HP 15-ay052nr Fan Replacement: 步骤 9 中的图像 1,1
      • Unplug the fan cable from the motherboard.
      • The fan can now be removed.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 24
总计 775
