跳转到主内容
加入维修社区 - 创建账户
HP 15-R263DX Hard Drive Replacement
你所需要的
  1. HP 15-R263DX Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 HP 15-R263DX Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
    • Slide the battery out as shown in the picture.
    询问修复机器人
    添加评论
  2. HP 15-R263DX Hard Drive Replacement, Optical Drive: 步骤 2 中的图像 1,2 HP 15-R263DX Hard Drive Replacement, Optical Drive: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the small screw next to the disc engraving shown in the picture.
    询问修复机器人
    添加评论
  3. HP 15-R263DX Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Gently slide the optical drive out of the side of the computer.
    询问修复机器人
    添加评论
  4. HP 15-R263DX Hard Drive Replacement, HP 15-R263DX Disassembly: 步骤 4 中的图像 1,2 HP 15-R263DX Hard Drive Replacement, HP 15-R263DX Disassembly: 步骤 4 中的图像 2,2
    • Locate the two corner grips on the hinge side of the computer.
    • Using a metal spudger, remove the two corner grips to reveal the screws.
    询问修复机器人
    添加评论
  5. HP 15-R263DX Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Remove the 11 small screws on the bottom of the computer that are shown in the picture.
    询问修复机器人
    添加评论
  6. HP 15-R263DX Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Remove the 2 small screws that are on the bottom side of the disc tray slot.
    • These screws are shorter and wider than the others.
    询问修复机器人
    添加评论
  7. HP 15-R263DX Hard Drive Replacement: 步骤 7 中的图像 1,2 HP 15-R263DX Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Once the keyboard is loose, do not immediately pull away from computer. It is attached by the ribbon connector.
    • Using a spudger, pry around the edges of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
    • To disconnect the ribbon connector, flip up the black clip shown in the picture.
    • Gently pull the ribbon until disconnected.
    添加评论
  8. HP 15-R263DX Hard Drive Replacement: 步骤 8 中的图像 1,2 HP 15-R263DX Hard Drive Replacement: 步骤 8 中的图像 2,2
    • Disconnect the other two ribbon connectors underneath the keyboard by fliping up the black clips.
    • Remove the 4 small screws shown in the picture.
    询问修复机器人
    添加评论
  9. HP 15-R263DX Hard Drive Replacement: 步骤 9 中的图像 1,1
    • Disengage the face plate clips by prying the case away from around the outer edge of the face plate with a metal wedge.
    • The face plate can then be lifted away from the computer.
    询问修复机器人
    添加评论
  10. HP 15-R263DX Hard Drive Replacement, Hard Drive: 步骤 10 中的图像 1,1
    • Remove the 2 black screws holding the hard drive to the computer frame.
    询问修复机器人
    添加评论
  11. HP 15-R263DX Hard Drive Replacement: 步骤 11 中的图像 1,2 HP 15-R263DX Hard Drive Replacement: 步骤 11 中的图像 2,2
    • Gently slide the hard drive away from the motherboard to disconnect it.
    • After it's disconnected, lift the hard drive up to remove it from the computer.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Drake Hort
于03/05/18注册
487 声望
创作了3篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 32
总计 1,912
