跳转到主内容
加入维修社区 - 创建账户
HMD Barbie Motherboard Replacement
你所需要的
    1. HMD Barbie Motherboard Replacement, Battery: 步骤 1 中的图像 1,3 HMD Barbie Motherboard Replacement, Battery: 步骤 1 中的图像 2,3 HMD Barbie Motherboard Replacement, Battery: 步骤 1 中的图像 3,3
      • Fully power off the phone.
      • Remove the backplate by gripping it around the edges and pulling away from the phone.
      询问修复机器人
      添加评论
    2. HMD Barbie Motherboard Replacement: 步骤 2 中的图像 1,3 HMD Barbie Motherboard Replacement: 步骤 2 中的图像 2,3 HMD Barbie Motherboard Replacement: 步骤 2 中的图像 3,3
      • Grip the battery from the top and pull away from the phone.
      • Ensure there is no swelling or damage to the battery. A swollen or damaged battery can be a fire hazard.
      询问修复机器人
      添加评论
    1. HMD Barbie Motherboard Replacement, Inner Backplate: 步骤 3 中的图像 1,1
      • Remove the six 5mm screws using the T5 Torx screwdriver.
      询问修复机器人
      添加评论
    2. HMD Barbie Motherboard Replacement: 步骤 4 中的图像 1,2 HMD Barbie Motherboard Replacement: 步骤 4 中的图像 2,2
      • Remove the backplate using an opening tool.
      • Find an opening on the phone that makes it easiest to remove the backplate. Any side of the phone will work.
      询问修复机器人
      添加评论
    1. HMD Barbie Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,3 HMD Barbie Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,3 HMD Barbie Motherboard Replacement, Motherboard: 步骤 5 中的图像 3,3
      • Use the opening tool to remove the clear plastic clip near the hinge of the phone securing the motherboard.
      询问修复机器人
      添加评论
    2. HMD Barbie Motherboard Replacement: 步骤 6 中的图像 1,3 HMD Barbie Motherboard Replacement: 步骤 6 中的图像 2,3 HMD Barbie Motherboard Replacement: 步骤 6 中的图像 3,3
      • The video ribbon is connected to the motherboard with a flat-topped, low profile connector. It is also secured with a piece of tape.
      • Use the tweezers to gently unstick the tape from the motherboard, leaving it stuck to the connector.
      • Use the tweezers to gently pull up on the connector until it disconnects from the motherboard.
      • Be gentle as you apply pressure on the tape and connector. These parts shouldn't take too much force to remove.
      询问修复机器人
      添加评论
    3. HMD Barbie Motherboard Replacement: 步骤 7 中的图像 1,3 HMD Barbie Motherboard Replacement: 步骤 7 中的图像 2,3 HMD Barbie Motherboard Replacement: 步骤 7 中的图像 3,3
      • Beginning at the corner near where the video ribbon is located, insert an opening pick between the green motherboard and the pink housing.
      • Slowly work your way around the motherboard until it loosens enough that you can use your fingers to remove it.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
UMass Dartmouth, Team 6-2, Botvin Spring 2026 UMass Dartmouth, Team 6-2, Botvin Spring 2026 的会员
UMASSD-BOTVIN-S26S6G2
3 名成员
创作了45篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 47
总计 128
