跳转到主内容
加入维修社区 - 创建账户
Graco Secure Coverage LED Parent Unit Replacement
你所需要的
  1. Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: 步骤 1 中的图像 1,3 Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: 步骤 1 中的图像 2,3 Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: 步骤 1 中的图像 3,3
    • Using plastic opening tool, pry and remove the battery lid.
    询问修复机器人
    添加评论
  2. Graco Secure Coverage LED Parent Unit Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
    • Make sure that you disconnect the battery's wire before you remove the battery.
    询问修复机器人
    添加评论
  3. Graco Secure Coverage LED Parent Unit Replacement, LED Parent Unit: 步骤 3 中的图像 1,2 Graco Secure Coverage LED Parent Unit Replacement, LED Parent Unit: 步骤 3 中的图像 2,2
    • There are two screws on the rare case of the device. For the one shown in blue marker requires either an extended screwdriver or putting on a little pressure on a regular screwdriver.
    • Remove the two 9mm Phillips #1 screws from the rare case of the device.
    • If you cannot remove the screw with low pressure, do not use high pressure to remove it. It may cause a damage on the device case. Use an extended screwdriver instead.
    询问修复机器人
    添加评论
  4. Graco Secure Coverage LED Parent Unit Replacement: 步骤 4 中的图像 1,2 Graco Secure Coverage LED Parent Unit Replacement: 步骤 4 中的图像 2,2
    • Using opening plastic tool, pry the two grey cases from both sides of the device.
    • Take your time and apply constant force to avoid breaking or damaging any other plastic parts.
    • While pry off the grey cases, hold the device with your other hand to remove the cases
    询问修复机器人
    添加评论
  5. Graco Secure Coverage LED Parent Unit Replacement: 步骤 5 中的图像 1,1
    • Pry the edges of the device to separate the front and rare cases.
    • While prying the edges, hold the device with one hand to pull out each case a part.
    • Make sure you use a constant force, and the pushbuttons are pried off completely.
    询问修复机器人
    添加评论
  6. Graco Secure Coverage LED Parent Unit Replacement: 步骤 6 中的图像 1,2 Graco Secure Coverage LED Parent Unit Replacement: 步骤 6 中的图像 2,2
    • Remove the 7mm Phillips #1 screw from the mother board.
    • Place the screw in a secure place.
    询问修复机器人
    添加评论
  7. Graco Secure Coverage LED Parent Unit Replacement: 步骤 7 中的图像 1,2 Graco Secure Coverage LED Parent Unit Replacement: 步骤 7 中的图像 2,2
    • Flip over the motherboard.
    • Solder off LED from motherboard.
    • There are many pins attached to the motherboard, make sure you solder off the proper pins that attached to the LED's.
    • Replace the LED's
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Bryson Wolff
于08/31/15注册
237 声望
创作了2篇指南
团队
USF Tampa, Team 6-5, Remmell Fall 2015 USF Tampa, Team 6-5, Remmell Fall 2015 的会员
USFT-REMMELL-F15S6G5
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 29
总计 375
