跳转到主内容
加入维修社区 - 创建账户
Google Pixel C Power Button Replacement
你所需要的
    1. Google Pixel C Power Button Replacement, Screen: 步骤 1 中的图像 1,1
      • Ensure that the device is completely powered down before beginning to take it apart
      • Use a heat gun to melt the adhesive that holds the screen to the device
      • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
      • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
      询问修复机器人
      添加评论
    2. Google Pixel C Power Button Replacement: 步骤 2 中的图像 1,2 Google Pixel C Power Button Replacement: 步骤 2 中的图像 2,2
      • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
      • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
      • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
      • Reattaching the screen will require adhesive to ensure that it stays in place.
      添加评论
    3. Google Pixel C Power Button Replacement: 步骤 3 中的图像 1,2 Google Pixel C Power Button Replacement: 步骤 3 中的图像 2,2
      • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
      添加评论
    4. Google Pixel C Power Button Replacement: 步骤 4 中的图像 1,2 Google Pixel C Power Button Replacement: 步骤 4 中的图像 2,2
      在这个步骤中使用的工具:
      • Follow the same removal procedure to detach the wide gold cable.
      • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
      • This device is missing a battery, so the device that you are working on may appear slightly different inside.
      添加评论
    1. Google Pixel C Power Button Replacement, Power Button: 步骤 5 中的图像 1,1
      • Locate the power button along the edge of the tablet.
      • The actual power button technology is the black plastic piece located directly inside the device behind the silver button; this is what will be replaced.
      询问修复机器人
      添加评论
    2. Google Pixel C Power Button Replacement: 步骤 6 中的图像 1,2 Google Pixel C Power Button Replacement: 步骤 6 中的图像 2,2
      • Locate and remove the black 4.3mm Phillips #000 screw.
      • Remove the remaining two silver 4.2mm Phillips #000 screws.
      询问修复机器人
      添加评论
    3. Google Pixel C Power Button Replacement: 步骤 7 中的图像 1,2 Google Pixel C Power Button Replacement: 步骤 7 中的图像 2,2
      在这个步骤中使用的工具:
      • Use tweezers to slowly pull up on the power button technology as far as possible without pulling out the two black wires attached.
      • Don't pull up too hard, as the wires could be ripped out and damaged.
      询问修复机器人
      添加评论
    4. Google Pixel C Power Button Replacement: 步骤 8 中的图像 1,2 Google Pixel C Power Button Replacement: 步骤 8 中的图像 2,2
      • Detach the larger connector wire by flipping the copper hinge located at the base of the connection with your fingernail.
      询问修复机器人
      添加评论
    5. Google Pixel C Power Button Replacement: 步骤 9 中的图像 1,1
      • Flip the hinge of the second, more narrow wire to release the connection.
      • Don't pull the power button technology out yet. This wire is attached at one more place in the device.
      询问修复机器人
      添加评论
    6. Google Pixel C Power Button Replacement: 步骤 10 中的图像 1,2 Google Pixel C Power Button Replacement: 步骤 10 中的图像 2,2
      • Locate and remove the three 4.2mm Phillips #000 screws at the base of where the second wire is still connected.
      询问修复机器人
      添加评论
    7. Google Pixel C Power Button Replacement: 步骤 11 中的图像 1,2 Google Pixel C Power Button Replacement: 步骤 11 中的图像 2,2
      • Once all the screws are removed, gently pull up on the entire power button technology piece, to remove it from the device.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order. New adhesive will be needed to re-apply the screen.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Isabelle Tang
于04/26/17注册
225 声望
创作了2篇指南
团队
Cal Poly, Team S21-G4, Livingston Spring 2017 Cal Poly, Team S21-G4, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S21G4
4 名成员
创作了11篇指南
1指南评论
I have replaced the power/volume button flex with these instructions with a reportably working item, but power button still doesn't work. The volume buttons work just fine. Any other ideas about what might be the problem?
Colleen Price - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 52
总计 3,160
