跳转到主内容
加入维修社区 - 创建账户
Google Pixel C Keyboard Replacement
你所需要的
    1. Google Pixel C Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
      • Heat the black plastic strip on the front lower edge of the keyboard with an iOpener to weaken the adhesive holding it down.
      • When reattaching the plastic strip, apply adhesive to ensure that the strip will stay securely in place.
      询问修复机器人
      添加评论
    2. Google Pixel C Keyboard Replacement: 步骤 2 中的图像 1,2 Google Pixel C Keyboard Replacement: 步骤 2 中的图像 2,2
      • Use a medium plastic opening tool to lift the black plastic strip from the lower edge of the keyboard.
      询问修复机器人
      添加评论
    3. Google Pixel C Keyboard Replacement: 步骤 3 中的图像 1,2 Google Pixel C Keyboard Replacement: 步骤 3 中的图像 2,2
      • Locate the four 3.1mm Phillips #000 screws that hold the keyboard to the back plate.
      • Using the Phillips #000 Screwdriver, remove the screws from the keyboard.
      • The screws are reverse threaded, so turn them clockwise to remove them.
      询问修复机器人
      添加评论
    4. Google Pixel C Keyboard Replacement: 步骤 4 中的图像 1,1
      • Orient the keyboard so that the side with the keys is facedown on the table.
      • Use either an iFixit iOpener OR a heat gun to melt the adhesive that holds the top half of the keyboard to the bottom.
      • When using a heat gun for removal, only heat the backside of the keyboard to avoid warping the keys.
      询问修复机器人
      添加评论
    5. Google Pixel C Keyboard Replacement: 步骤 5 中的图像 1,3 Google Pixel C Keyboard Replacement: 步骤 5 中的图像 2,3 Google Pixel C Keyboard Replacement: 步骤 5 中的图像 3,3
      • Using a plastic or nylon spudger, pry the two halves of the keyboard apart.
      • If the plastic spudger doesn’t work, it is okay to use a metal spudger, but take care not to scratch or damage the device.
      • Be mindful of the amount of force applied to avoid snapping the keyboard.
      • It will be necessary to use adhesive to ensure that the keyboard is securely in place during reassembly.
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Cal Poly, Team S21-G4, Livingston Spring 2017 Cal Poly, Team S21-G4, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S21G4
4 名成员
创作了11篇指南
1指南评论
Uninstall a Pixel c's keyboard case's battery system,The Battery is out of life, but the case cost Pixel c's power while closed. No suitable battery to replace temporarily. Use a Hot Gun with higher temparature but control the temparature not too high then you will easily peal off the skin but no any broken and finally you can adhere it back to normal.Finished and accept. Now I just use the case as a case only and no need consider it cost the power.
bgzhang - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 33
总计 2,483
