跳转到主内容
加入维修社区 - 创建账户
Google Pixel 9 Autofocus and Flash Module Replacement
你所需要的
  1. Google Pixel 9 Autofocus and Flash Module Replacement, Prepare your Pixel for disassembly: 步骤 1 中的图像 1,3 Google Pixel 9 Autofocus and Flash Module Replacement, Prepare your Pixel for disassembly: 步骤 1 中的图像 2,3 Google Pixel 9 Autofocus and Flash Module Replacement, Prepare your Pixel for disassembly: 步骤 1 中的图像 3,3
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
    询问修复机器人
  2. Google Pixel 9 Autofocus and Flash Module Replacement, Adhesive information: 步骤 2 中的图像 1,3 Google Pixel 9 Autofocus and Flash Module Replacement, Adhesive information: 步骤 2 中的图像 2,3 Google Pixel 9 Autofocus and Flash Module Replacement, Adhesive information: 步骤 2 中的图像 3,3
    • Adhesive secures the perimeter of the back glass to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the back glass to avoid damaging the internal components.
    • To help, measure and mark 3 mm from the tip of an opening pick with a permanent marker.
    • If your screen or back glass is badly cracked, a suction cup may not perfectly adhere.
    • Lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier. Ensure there's a smooth area near the bottom edge that's large and smooth enough for a suction cup to stick to.
    询问修复机器人
  3. Google Pixel 9 Autofocus and Flash Module Replacement, Apply a suction handle: 步骤 3 中的图像 1,2 Google Pixel 9 Autofocus and Flash Module Replacement, Apply a suction handle: 步骤 3 中的图像 2,2
    • Place a suction handle at the bottom edge of the back glass, as close to the edge as possible.
    • Push down to attach the suction cup.
    询问修复机器人
  4. Google Pixel 9 Autofocus and Flash Module Replacement, Insert an opening pick: 步骤 4 中的图像 1,3 Google Pixel 9 Autofocus and Flash Module Replacement, Insert an opening pick: 步骤 4 中的图像 2,3 Google Pixel 9 Autofocus and Flash Module Replacement, Insert an opening pick: 步骤 4 中的图像 3,3
    • Pull up on the suction handle with strong, steady force to create a small gap under the back glass.
    • Insert the tip of an opening pick into the gap.
    询问修复机器人
  5. Google Pixel 9 Autofocus and Flash Module Replacement, Separate the back glass adhesive: 步骤 5 中的图像 1,3 Google Pixel 9 Autofocus and Flash Module Replacement, Separate the back glass adhesive: 步骤 5 中的图像 2,3 Google Pixel 9 Autofocus and Flash Module Replacement, Separate the back glass adhesive: 步骤 5 中的图像 3,3
    • Slide the opening pick back and forth along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
    询问修复机器人
  6. Google Pixel 9 Autofocus and Flash Module Replacement: 步骤 6 中的图像 1,3 Google Pixel 9 Autofocus and Flash Module Replacement: 步骤 6 中的图像 2,3 Google Pixel 9 Autofocus and Flash Module Replacement: 步骤 6 中的图像 3,3
    • Slide the opening pick around the perimeter of the phone, slicing the rest of the adhesive.
    询问修复机器人
  7. Google Pixel 9 Autofocus and Flash Module Replacement: 步骤 7 中的图像 1,3 Google Pixel 9 Autofocus and Flash Module Replacement: 步骤 7 中的图像 2,3 Google Pixel 9 Autofocus and Flash Module Replacement: 步骤 7 中的图像 3,3
    • With most of the adhesive separated, lightly twist the opening pick at the bottom edge to lift the back glass up until you can grip it with your fingers.
    • Use the opening pick to separate any remaining sections of adhesive securing the back glass.
    询问修复机器人
  8. Google Pixel 9 Autofocus and Flash Module Replacement, Remove the back glass: 步骤 8 中的图像 1,1
    • Remove the back glass.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your back glass.
    询问修复机器人
  9. Google Pixel 9 Autofocus and Flash Module Replacement, Remove the upper board cover: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    FixMat
    $36.95
    • While the Pixel 9 uses Torx Plus screws, standard Torx bits also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a 3IP Torx Plus driver to remove the single 5.4 mm‑long screw securing the upper board cover.
    询问修复机器人
  10. Google Pixel 9 Autofocus and Flash Module Replacement: 步骤 10 中的图像 1,2 Google Pixel 9 Autofocus and Flash Module Replacement: 步骤 10 中的图像 2,2
    • Use a pair of tweezers to remove the upper board cover.
    询问修复机器人
  11. Google Pixel 9 Autofocus and Flash Module Replacement, Remove the midframe: 步骤 11 中的图像 1,1
    • Use a 3IP Torx driver to remove the five screws securing the midframe and wireless charging coil:
    • Four 5.4 mm-long screws
    • One 2.2 mm-long screw
    询问修复机器人
  12. Google Pixel 9 Autofocus and Flash Module Replacement, Peel up the flash cable: 步骤 12 中的图像 1,2 Google Pixel 9 Autofocus and Flash Module Replacement, Peel up the flash cable: 步骤 12 中的图像 2,2
    • Use a pair of tweezers to peel the flash cable off of the metal midframe.
    询问修复机器人
  13. Google Pixel 9 Autofocus and Flash Module Replacement, Remove the midframe: 步骤 13 中的图像 1,2 Google Pixel 9 Autofocus and Flash Module Replacement, Remove the midframe: 步骤 13 中的图像 2,2
    • Remove the midframe, wireless charging coil, and NFC assembly.
    询问修复机器人
  14. Google Pixel 9 Autofocus and Flash Module Replacement, Disconnect the battery: 步骤 14 中的图像 1,2 Google Pixel 9 Autofocus and Flash Module Replacement, Disconnect the battery: 步骤 14 中的图像 2,2
    • Use the tip of a spudger to pry up and disconnect the battery connector.
    询问修复机器人
  15. Google Pixel 9 Autofocus and Flash Module Replacement, Remove the antenna board cover: 步骤 15 中的图像 1,1
    • Use a 3IP Torx Plus driver to remove the 5.4 mm-long screw securing the antenna board cover.
    询问修复机器人
  16. Google Pixel 9 Autofocus and Flash Module Replacement: 步骤 16 中的图像 1,1
    • Use a pair of tweezers to remove the antenna board cover.
    询问修复机器人
  17. Google Pixel 9 Autofocus and Flash Module Replacement, Disconnect the autofocus cable: 步骤 17 中的图像 1,2 Google Pixel 9 Autofocus and Flash Module Replacement, Disconnect the autofocus cable: 步骤 17 中的图像 2,2
    • Use the tip of a spudger to pry up and disconnect the autofocus connector from the motherboard.
    询问修复机器人
  18. Google Pixel 9 Autofocus and Flash Module Replacement, Disconnect the flash: 步骤 18 中的图像 1,2 Google Pixel 9 Autofocus and Flash Module Replacement, Disconnect the flash: 步骤 18 中的图像 2,2
    • Use the tip of a spudger to pry up and disconnect the flash connector from the motherboard.
    询问修复机器人
  19. Google Pixel 9 Autofocus and Flash Module Replacement, Heat the LDAF adhesive: 步骤 19 中的图像 1,1
    • Heat an iOpener and apply it over the LDAF and flash module for one minute to soften the adhesive securing it to the rear camera module.
    询问修复机器人
  20. Google Pixel 9 Autofocus and Flash Module Replacement, Remove the LDAF and flash module: 步骤 20 中的图像 1,3 Google Pixel 9 Autofocus and Flash Module Replacement, Remove the LDAF and flash module: 步骤 20 中的图像 2,3 Google Pixel 9 Autofocus and Flash Module Replacement, Remove the LDAF and flash module: 步骤 20 中的图像 3,3
    • Peel up and remove the LDAF and flash module.
    • During reassembly, orient the module such that the longer cable is on the bottom edge.
    • Be very careful not to touch the rear camera lenses. If you accidentally do, wipe them with a clean microfiber cloth.
    询问修复机器人
  21. Google Pixel 9 Autofocus and Flash Module Replacement, Reassembly information: 步骤 21 中的图像 1,3 Google Pixel 9 Autofocus and Flash Module Replacement, Reassembly information: 步骤 21 中的图像 2,3 Google Pixel 9 Autofocus and Flash Module Replacement, Reassembly information: 步骤 21 中的图像 3,3
    • Use a spudger and tweezers to remove the two pieces of adhesive from the bottom of the LDAF and flash module.
    • Remove the larger clear liners from one of the flash module adhesives.
    • Place the adhesive into place on the bottom of the module and press down firmly with the flat end of a spudger to secure the adhesive.
    • Repeat the process to apply the other piece of flash adhesive.
    • Remove the two remaining blue liners.
    询问修复机器人
结论
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 9 Answers Community for help.
Carsten Frauenheim
于03/10/20注册
164,717 声望
创作了439篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了25,718篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 102
总计 1,377
