跳转到主内容
加入维修社区 - 创建账户
Google Pixel 2 Display Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Google Pixel 2 Display Replacement, Display: 步骤 1 中的图像 1,2 Google Pixel 2 Display Replacement, Display: 步骤 1 中的图像 2,2
    • Heat up the iOpener in the microwave for 30 seconds.
    • Place the iOpener clear-side down on each edge of the phone for approximately 30 seconds.
    • Place the iOpener on top of the screen for an additional 30 seconds.
    • Be careful with the iOpener as it will get extremely hot.
    询问修复机器人
    添加评论
  2. Google Pixel 2 Display Replacement: 步骤 2 中的图像 1,3 Google Pixel 2 Display Replacement: 步骤 2 中的图像 2,3 Google Pixel 2 Display Replacement: 步骤 2 中的图像 3,3
    • Attach the suction cup to the display by placing it on top of the display and pushing down on the top of the cup until it is flat.
    • Separate the display and the device by inserting the plastic opening tool between them and sliding the plastic opening tool along the perimeter of the display.
    • It is normal to hear popping noises as the plastic opening tool breaks the connection between the display and the device.
    • Remove the display from the device by grabbing the ring of the suction cup and pulling up.
    询问修复机器人
    添加评论
  3. Google Pixel 2 Display Replacement: 步骤 3 中的图像 1,3 Google Pixel 2 Display Replacement: 步骤 3 中的图像 2,3 Google Pixel 2 Display Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    • Remove the T4 4.0-mm screws from the latch under the display by turning the screwdriver counterclockwise.
    • Pull the latch off of the device by grabbing it with the tweezers and pulling up.
    询问修复机器人
    添加评论
  4. Google Pixel 2 Display Replacement: 步骤 4 中的图像 1,1
    • Remove the connector underneath the latch by grabbing it with the tweezers and lifting up.
    • It is normal to hear a popping noise during this step.
    • When reassembling, simply use your finger to pop this piece back into place by pushing it down into the device.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Monica Andres
于01/24/18注册
289 声望
创作了2篇指南
团队
Cal Poly, Team S18-G5, Livingston Winter 2018 Cal Poly, Team S18-G5, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S18G5
4 名成员
创作了29篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 31
总计 1,363
