跳转到主内容
加入维修社区 - 创建账户
Google Home Motherboard Replacement
你所需要的
  1. Google Home Motherboard Replacement, Interconnect Cable: 步骤 1 中的图像 1,3 Google Home Motherboard Replacement, Interconnect Cable: 步骤 1 中的图像 2,3 Google Home Motherboard Replacement, Interconnect Cable: 步骤 1 中的图像 3,3
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
    询问修复机器人
    添加评论
  2. Google Home Motherboard Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    • Carefully remove the interconnect cable using a pair of tweezers.
    询问修复机器人
    添加评论
  3. Google Home Motherboard Replacement, Mute Button Switch: 步骤 3 中的图像 1,2 Google Home Motherboard Replacement, Mute Button Switch: 步骤 3 中的图像 2,2
    • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
    询问修复机器人
    添加评论
  4. Google Home Motherboard Replacement: 步骤 4 中的图像 1,2 Google Home Motherboard Replacement: 步骤 4 中的图像 2,2
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
    • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
    询问修复机器人
    添加评论
  5. Google Home Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,2 Google Home Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Disconnect the foam-padded, red and black cable that connects the motherboard to the sound driver, by squeezing and pulling on the tab
    • Disconnect the orange interconnect cable that connects the bottom of the device to the motherboard by pulling straight out on the orange tab.
    询问修复机器人
    添加评论
  6. Google Home Motherboard Replacement: 步骤 6 中的图像 1,2 Google Home Motherboard Replacement: 步骤 6 中的图像 2,2
    • Using a Torx T6 screwdriver head, unscrew the five silver 1.7mm Torx screws keeping the motherboard in place.
    • Remove the motherboard.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Maya Wharton
于04/17/18注册
193 声望
撰写一个指南
团队
Cal Poly, Team S24-G11, Maness Spring 2018 Cal Poly, Team S24-G11, Maness Spring 2018 的会员
CPSU-MANESS-S18S24G11
4 名成员
创作了5篇指南
2指南评论
Where can one purchase a replacement motherboard?
Jim Pflasterer - 回复 分享
Most likely the only place to do so would be through contacting Google, as there is no parts sold at retail, only full units
Nick Bergstrom - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 64
总计 3,934
