跳转到主内容
加入维修社区 - 创建账户
GoPro Hero4 Silver Image Sensor Replacement
你所需要的
    1. GoPro Hero4 Silver Image Sensor Replacement, Front Panel: 步骤 1 中的图像 1,3 GoPro Hero4 Silver Image Sensor Replacement, Front Panel: 步骤 1 中的图像 2,3 GoPro Hero4 Silver Image Sensor Replacement, Front Panel: 步骤 1 中的图像 3,3
      • Start by removing the silver plastic face from the camera using a plastic opening tool. Insert the plastic opening tool into the middle of each edge and lift up the tabs that keep the camera face on.
      • The seven plastic tab locations are marked in red.
      • Try using the plastic opening tool before switching to the metal spudger. We tried using the plastic opening tool to pry the camera face off, but found that it did not give us enough leverage.
      • There may be glue holding the camera face on to the housing. Be careful not to flex the camera face too much, or it will crack.
      添加评论
    1. GoPro Hero4 Silver Image Sensor Replacement, Image Sensor: 步骤 2 中的图像 1,1
      • Remove the three 8 mm Phillips #000 screws on each corner of the camera.
      • Remove the single 4 mm Phillips #000 screw on the bottom left corner of the camera.
      添加评论
    2. GoPro Hero4 Silver Image Sensor Replacement: 步骤 3 中的图像 1,2 GoPro Hero4 Silver Image Sensor Replacement: 步骤 3 中的图像 2,2
      • To remove the motherboard assembly from the camera casing, use the plastic opening tool on the lens side of the camera to pry the motherboard assembly out of the camera housing.
      • To avoid breaking the plastic on the lens side of the camera (see photo), pry along the edges near the corners.
      • Try using the plastic opening tool before switching to the metal spudger. We tried using the plastic opening tool to pry the motherboard assembly open, but found that it did not give us enough leverage.
      • Do not try to pry near the power button side of the camera. This will break important cables inside.
      询问修复机器人
      添加评论
    3. GoPro Hero4 Silver Image Sensor Replacement: 步骤 4 中的图像 1,2 GoPro Hero4 Silver Image Sensor Replacement: 步骤 4 中的图像 2,2
      • Remove the four 8 mm Phillips #000 screws securing the camera sensor assembly.
      询问修复机器人
      添加评论
    4. GoPro Hero4 Silver Image Sensor Replacement: 步骤 5 中的图像 1,3 GoPro Hero4 Silver Image Sensor Replacement: 步骤 5 中的图像 2,3 GoPro Hero4 Silver Image Sensor Replacement: 步骤 5 中的图像 3,3
      • To remove the sensor assembly, simply peel off the lens towards the attached ribbon cable.
      • The sensor has ribbon cables running to the motherboard via a black rectangular connector.
      • To remove the sensor, use the spudger to pry up each side, Then, lift the connector straight up from its socket.
      • With the old camera sensor assembly removed, you can now replace it with a new sensor.
      添加评论
结论
取消:我没有完成这个指南。
11等其他人完成本指南。
团队
USF Tampa, Team 2-1, Blackwell Fall 2015 USF Tampa, Team 2-1, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S2G1
4 名成员
创作了20篇指南
3指南评论
Did GoPro make an updated version of the sensor, or are all the ones sold on the web just the same as the one that keeps failing in the cameras? Do you have a part number for the sensor that is supposed to work better? No point replacing the sensor with the same one the camera came with as it will likely fail withing a year just like the original one. Please advice.
David Kvick - 回复 分享
thanks for the instructions - easy to understand and carry out. my GoPro 4 is now up and running again
Nigel Jones - 回复 分享
Pregunta el sensor de la go pro hero 4 black es el mismo de la gopro hero 4 silver???
Jacinto - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 50
总计 15,038
