跳转到主内容
加入维修社区 - 创建账户
GoPro Hero3+ Silver Edition Image Sensor Replacement
你所需要的
  1. GoPro Hero3+ Silver Edition Image Sensor Replacement, Battery: 步骤 1 中的图像 1,2 GoPro Hero3+ Silver Edition Image Sensor Replacement, Battery: 步骤 1 中的图像 2,2
    • Push the tab on the back of the device left to remove the plate covering the battery.
    询问修复机器人
    添加评论
  2. GoPro Hero3+ Silver Edition Image Sensor Replacement: 步骤 2 中的图像 1,1
    • Use the strip of tape on the battery to remove the battery from the housing.
    询问修复机器人
    添加评论
  3. GoPro Hero3+ Silver Edition Image Sensor Replacement, Front Panel: 步骤 3 中的图像 1,1
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
    询问修复机器人
    添加评论
  4. GoPro Hero3+ Silver Edition Image Sensor Replacement: 步骤 4 中的图像 1,1
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
    询问修复机器人
    添加评论
  5. GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: 步骤 5 中的图像 1,3 GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: 步骤 5 中的图像 2,3 GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: 步骤 5 中的图像 3,3
    • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
    • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
    • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
    添加评论
  6. GoPro Hero3+ Silver Edition Image Sensor Replacement: 步骤 6 中的图像 1,2 GoPro Hero3+ Silver Edition Image Sensor Replacement: 步骤 6 中的图像 2,2
    • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
    询问修复机器人
    添加评论
  7. GoPro Hero3+ Silver Edition Image Sensor Replacement: 步骤 7 中的图像 1,1
    • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
    询问修复机器人
    添加评论
  8. GoPro Hero3+ Silver Edition Image Sensor Replacement: 步骤 8 中的图像 1,2 GoPro Hero3+ Silver Edition Image Sensor Replacement: 步骤 8 中的图像 2,2
    • Pry off the last ribbon cable with a plastic opening tool.
    • Remove the image sensor from the motherboard.
    添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
Cal Poly, Team 5-8, Maness Fall 2015 Cal Poly, Team 5-8, Maness Fall 2015 的会员
CPSU-MANESS-F15S5G8
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 34
总计 1,171
