跳转到主内容
加入维修社区 - 创建账户
GoPro Hero3+ Silver Edition Camera Lens Replacement
你所需要的
  1. GoPro Hero3+ Silver Edition Camera Lens Replacement, Battery: 步骤 1 中的图像 1,2 GoPro Hero3+ Silver Edition Camera Lens Replacement, Battery: 步骤 1 中的图像 2,2
    • Push the tab on the back of the device left to remove the plate covering the battery.
    询问修复机器人
    添加评论
  2. GoPro Hero3+ Silver Edition Camera Lens Replacement: 步骤 2 中的图像 1,1
    • Use the strip of tape on the battery to remove the battery from the housing.
    询问修复机器人
    添加评论
  3. GoPro Hero3+ Silver Edition Camera Lens Replacement, Front Panel: 步骤 3 中的图像 1,1
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
    询问修复机器人
    添加评论
  4. GoPro Hero3+ Silver Edition Camera Lens Replacement: 步骤 4 中的图像 1,1
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
    询问修复机器人
    添加评论
  5. GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: 步骤 5 中的图像 1,3 GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: 步骤 5 中的图像 2,3 GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: 步骤 5 中的图像 3,3
    • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
    • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
    • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
    添加评论
  6. GoPro Hero3+ Silver Edition Camera Lens Replacement: 步骤 6 中的图像 1,2 GoPro Hero3+ Silver Edition Camera Lens Replacement: 步骤 6 中的图像 2,2
    • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
    询问修复机器人
    添加评论
  7. GoPro Hero3+ Silver Edition Camera Lens Replacement: 步骤 7 中的图像 1,1
    • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
    询问修复机器人
    添加评论
  8. GoPro Hero3+ Silver Edition Camera Lens Replacement: 步骤 8 中的图像 1,2 GoPro Hero3+ Silver Edition Camera Lens Replacement: 步骤 8 中的图像 2,2
    • Pry off the last ribbon cable with a plastic opening tool.
    • Remove the image sensor from the motherboard.
    添加评论
  9. GoPro Hero3+ Silver Edition Camera Lens Replacement, microSD/Expansion Port Assembly: 步骤 9 中的图像 1,1
    • Using your screwdriver, unscrew three 4mm PH00 screws that will free the metal plate.
    • A small plate will become separated when the rightmost screw is removed. Just place it to the side.
    询问修复机器人
    添加评论
  10. GoPro Hero3+ Silver Edition Camera Lens Replacement: 步骤 10 中的图像 1,2 GoPro Hero3+ Silver Edition Camera Lens Replacement: 步骤 10 中的图像 2,2
    • Use the plastic opening tool to pry off the referenced ribbon cable from the motherboard.
    • The microSD and Accessory Board is now ready for removal.
    询问修复机器人
    添加评论
  11. GoPro Hero3+ Silver Edition Camera Lens Replacement, Motherboard: 步骤 11 中的图像 1,1
    • Remove the single 3.2mm PH00 screw with your screwdriver to detach the motherboard from the mid frame.
    询问修复机器人
    添加评论
  12. GoPro Hero3+ Silver Edition Camera Lens Replacement: 步骤 12 中的图像 1,3 GoPro Hero3+ Silver Edition Camera Lens Replacement: 步骤 12 中的图像 2,3 GoPro Hero3+ Silver Edition Camera Lens Replacement: 步骤 12 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a plastic opening tool to gently separate the LCD ribbon cable from the motherboard.
    • Gently remove the motherboard from the midframe using tweezers.
    • Remove motherboard by lifting from the edges. This will reduce the chance of damaging components on the motherboard.
    询问修复机器人
    添加评论
  13. GoPro Hero3+ Silver Edition Camera Lens Replacement, Camera Lens: 步骤 13 中的图像 1,1
    • Use your PH00 screwdriver to remove the last three screws from the mid frame. This will release the lens housing from the mid frame.
    询问修复机器人
    添加评论
  14. GoPro Hero3+ Silver Edition Camera Lens Replacement: 步骤 14 中的图像 1,1
    • Carefully remove the lens from the font housing.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
9等其他人完成本指南。
团队
Cal Poly, Team 5-8, Maness Fall 2015 Cal Poly, Team 5-8, Maness Fall 2015 的会员
CPSU-MANESS-F15S5G8
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 26
总计 2,571
