跳转到主内容
加入维修社区 - 创建账户
GoPro Hero Lens Replacement
你所需要的
    1. GoPro Hero Lens Replacement, Casing: 步骤 1 中的图像 1,1
      • Power off your GoPro before beginning disassembly.
      • Unclip the black latch to the camera case and open the case.
      询问修复机器人
      添加评论
    2. GoPro Hero Lens Replacement: 步骤 2 中的图像 1,1
      • Gently pry the back open by inserting a metal spudger between the case and back panel.
      询问修复机器人
      添加评论
    3. GoPro Hero Lens Replacement: 步骤 3 中的图像 1,1
      • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
      询问修复机器人
      添加评论
    4. GoPro Hero Lens Replacement: 步骤 4 中的图像 1,1
      • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
      询问修复机器人
      添加评论
    5. GoPro Hero Lens Replacement: 步骤 5 中的图像 1,1
      • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
      • Make sure to keep track of these screws as they are very small.
      询问修复机器人
      添加评论
    6. GoPro Hero Lens Replacement: 步骤 6 中的图像 1,1
      • Carefully remove the motherboard and white plastic piece from the case.
      询问修复机器人
      添加评论
    1. GoPro Hero Lens Replacement, Lens: 步骤 7 中的图像 1,1
      • Remove the four screws from the lens.
      • These screws are smaller than the ones removed from the white plastic piece.
      询问修复机器人
      添加评论
    2. GoPro Hero Lens Replacement: 步骤 8 中的图像 1,1
      • Remove the lens from the case.
      添加评论
结论
To reassemble your device, follow the instructions in reverse order.
取消:我没有完成这个指南。
3等其他人完成本指南。
River Drake
于04/02/15注册
1,065 声望
创作了5篇指南
团队
Cal Poly, Team 12-2, Lancaster Spring 2015 Cal Poly, Team 12-2, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S12G2
4 名成员
创作了18篇指南
1指南评论
I followed this list, but I think I knocked a component off of the motherboard while I was unscrewing it. I wasn’t planning on ever putting it back together, since I have a newer GoPro camera. Luckily, the lens and the cable connecting it didn’t get damaged. Is there maybe a way to connect the lens to the Raspberry Pi Zero?
Doggo Boi - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 71
总计 14,214
