跳转到主内容
加入维修社区 - 创建账户
GoPro Hero LCD Screen Replacement
你所需要的
    1. GoPro Hero LCD Screen Replacement, Casing: 步骤 1 中的图像 1,1
      • Power off your GoPro before beginning disassembly.
      • Unclip the black latch to the camera case and open the case.
      询问修复机器人
      添加评论
    2. GoPro Hero LCD Screen Replacement: 步骤 2 中的图像 1,1
      • Gently pry the back open by inserting a metal spudger between the case and back panel.
      询问修复机器人
      添加评论
    3. GoPro Hero LCD Screen Replacement: 步骤 3 中的图像 1,1
      • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
      询问修复机器人
      添加评论
    4. GoPro Hero LCD Screen Replacement: 步骤 4 中的图像 1,1
      • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
      询问修复机器人
      添加评论
    5. GoPro Hero LCD Screen Replacement: 步骤 5 中的图像 1,1
      • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
      • Make sure to keep track of these screws as they are very small.
      询问修复机器人
      添加评论
    6. GoPro Hero LCD Screen Replacement: 步骤 6 中的图像 1,1
      • Carefully remove the motherboard and white plastic piece from the case.
      询问修复机器人
      添加评论
    1. GoPro Hero LCD Screen Replacement, LCD Screen: 步骤 7 中的图像 1,2 GoPro Hero LCD Screen Replacement, LCD Screen: 步骤 7 中的图像 2,2
      • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
      • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
      添加评论
    2. GoPro Hero LCD Screen Replacement: 步骤 8 中的图像 1,1
      • Separate the motherboard from the white piece of plastic.
      询问修复机器人
      添加评论
    3. GoPro Hero LCD Screen Replacement: 步骤 9 中的图像 1,1
      • Remove the ribbon cable from the motherboard by simply pulling the cable from the socket.
      询问修复机器人
      添加评论
    4. GoPro Hero LCD Screen Replacement: 步骤 10 中的图像 1,2 GoPro Hero LCD Screen Replacement: 步骤 10 中的图像 2,2
      • Separate the LCD screen from the motherboard.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
River Drake
于04/02/15注册
1,065 声望
创作了5篇指南
团队
Cal Poly, Team 12-2, Lancaster Spring 2015 Cal Poly, Team 12-2, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S12G2
4 名成员
创作了18篇指南
3指南评论
Where do you buy the replacement lcd
Anthony Volatile - 回复 分享
Gopro hero 7 white repair cost:
Screen: $45 - https://www.ebay.com.au/itm/183828969944
Side panel: $35 - https://www.herogear.com.au/genuine-repl...
Addisen KING - 回复 分享
I can find the screen but is it compatible with the Hero+
Brian Casado - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 50
过去 30 天: 155
总计 27,404
