跳转到主内容
加入维修社区 - 创建账户
GoPro Hero Battery Replacement
你所需要的
    1. GoPro Hero Battery Replacement, Battery: 步骤 1 中的图像 1,1
      • Power off your GoPro before beginning disassembly.
      • Unclip the black latch to the camera case and open the case.
      询问修复机器人
      添加评论
    2. GoPro Hero Battery Replacement: 步骤 2 中的图像 1,1
      • Gently pry the back open by inserting a metal spudger between the case and back panel.
      添加评论
    3. GoPro Hero Battery Replacement: 步骤 3 中的图像 1,1
      • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
      • Use a plastic spudger to pry the battery off from the white plastic piece underneath.
      • The battery is glued to the plastic so some force might be necessary.
      • Be careful not to damage the battery to avoid releasing dangerous chemicals.
      询问修复机器人
      添加评论
    4. GoPro Hero Battery Replacement: 步骤 4 中的图像 1,1
      • Remove the battery from the GoPro.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
29等其他人完成本指南。
River Drake
于04/02/15注册
1,065 声望
创作了5篇指南
团队
Cal Poly, Team 12-2, Lancaster Spring 2015 Cal Poly, Team 12-2, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S12G2
4 名成员
创作了18篇指南
20指南评论
The tutorial is excellent, even with a link to the tools needed, but no link to battery sale.
Could you please include this?
juliomap - 回复 分享
Very good tutorial thank you. But I can also find no place to buy a new battery... But here is a petition to make Gopro sell spare parts: https://www.change.org/p/gopro-support-o...
maire - 回复 分享
I followed these steps and inadvertently pulled not only the battery plug but its adapter (housing) at the same time. Now I can't plug the battery back in because there's no place to plug it! Contacting GoPro they stressed that the battery is not intended for removal.
erikwikstrom - 回复 分享
Awesome! Could you also show us how to put in a new battery, how do i prep my battery? What type of a battery can i use ? Thanks a lot !!
John misquita - 回复 分享
now add go pro to rice for a day and pray.
chadd23 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 66
过去 30 天: 271
总计 84,149
