跳转到主内容
加入维修社区 - 创建账户
GoPro Hero 3 Silver Rear Housing Replacement
你所需要的
    1. GoPro Hero 3 Silver Rear Housing Replacement, Battery: 步骤 1 中的图像 1,2 GoPro Hero 3 Silver Rear Housing Replacement, Battery: 步骤 1 中的图像 2,2
      • Pull back on the tab on the back of GoPro to open the battery cover.
      询问修复机器人
      添加评论
    2. GoPro Hero 3 Silver Rear Housing Replacement: 步骤 2 中的图像 1,1
      • Pull the battery out using the tab.
      询问修复机器人
      添加评论
    1. GoPro Hero 3 Silver Rear Housing Replacement, Rear Housing: 步骤 3 中的图像 1,2 GoPro Hero 3 Silver Rear Housing Replacement, Rear Housing: 步骤 3 中的图像 2,2
      • Use the plastic opening tool to remove the faceplate.
      • There is some adhesive and clips so be careful and the faceplate should pop right off.
      询问修复机器人
      添加评论
    2. GoPro Hero 3 Silver Rear Housing Replacement: 步骤 4 中的图像 1,2 GoPro Hero 3 Silver Rear Housing Replacement: 步骤 4 中的图像 2,2
      • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
      • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
      询问修复机器人
      添加评论
    3. GoPro Hero 3 Silver Rear Housing Replacement: 步骤 5 中的图像 1,2 GoPro Hero 3 Silver Rear Housing Replacement: 步骤 5 中的图像 2,2
      • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
      • Using the plastic opening tool, slowly pry open the motherboard assembly.
      询问修复机器人
      添加评论
    4. GoPro Hero 3 Silver Rear Housing Replacement: 步骤 6 中的图像 1,2 GoPro Hero 3 Silver Rear Housing Replacement: 步骤 6 中的图像 2,2
      • Use the spudger to gently pry off the connector of the housing to the motherboard.
      • You should now have the motherboard assembly and the housing separated.
      询问修复机器人
      添加评论
    5. GoPro Hero 3 Silver Rear Housing Replacement: 步骤 7 中的图像 1,1
      • In order to replace the buttons. The entire housing has to be replaced.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Brian Alvarez
于04/02/15注册
1,439 声望
创作了6篇指南
团队
Cal Poly, Team 24-7, Lancaster Spring 2015 Cal Poly, Team 24-7, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S24G7
3 名成员
创作了63篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 36
总计 2,878
