简介
Use this guide to replace the microSD/Micro USB port assembly in your GoPro Hero+ LCD.
你所需要的
Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
Remove the two 6 mm Phillips #00 screws.
Remove the single 4 mm Phillips #000 screws.
5等其他人完成本指南。
