跳转到主内容
加入维修社区 - 创建账户
Gigabyte P34G Battery Replacement
你所需要的
  1. Gigabyte P34G Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove all 15 screws on the underside of the laptop using a Phillips #0 screwdriver.
    • There are three different sized screws.
    • x1 9.8mm Screw
    • x8 5.6mm Screws
    • x6 5.0mm Screws
    询问修复机器人
    添加评论
  2. Gigabyte P34G Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the four 4.5 mm screws using a Phillips #0 screwdriver.
    • Save the screws in a safe place for reassembly later.
    询问修复机器人
    添加评论
  3. Gigabyte P34G Battery Replacement: 步骤 3 中的图像 1,1
    • Pull the wires down towards yourself to gently detach the connector from the main drive.
    • Save connector for reassembly later.
    询问修复机器人
    添加评论
  4. Gigabyte P34G Battery Replacement: 步骤 4 中的图像 1,1
    • Carefully lift the battery for removal and discard properly.
    • Replace with new battery.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
yeunghayden
于05/01/15注册
841 声望
创作了6篇指南
团队
Cal Poly, Team 8-1, Regan Spring 2015 Cal Poly, Team 8-1, Regan Spring 2015 的会员
CPSU-REGAN-S15S8G1
5 名成员
创作了12篇指南
12指南评论
Does anyone know where to find a replacement, or if you can fit the version 1 of this computer with a larger capacity battery from version 2?
tadej rezar - 回复 分享
Over at https://www.mysn.de/detail.asp?bestellnr... (don't mind their stock picture), they still sell the battery for the C404 (which is identical to the P34G v2). I just bought a new 61.25 Wh GNC-J40, manufactured in 2016/07.
M D - 回复 分享
Will it run without the battery or is it a required part of the circuit? I have a P35G V2 and I only use it plugged in anyway.
jens_lipponer - 回复 分享
The battery in my P34G v2 is pretty solidly stuck to the chassis. I don't really want to pull on it too hard but is this normal?
Donald Macaulay - 回复 分享
@jens_lipponer Yes it runs without the battery fine. I have my battery disconnected as it is really swolen and the laptop boots without a problem.
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 45
总计 20,412
