跳转到主内容
加入维修社区 - 创建账户
Giant Reign 2 Wheel Spoke Replacement
你所需要的
  1. Giant Reign 2 Wheel Spoke Replacement, Hex Screws: 步骤 1 中的图像 1,1
    • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
    询问修复机器人
    添加评论
  2. Giant Reign 2 Wheel Spoke Replacement, Axle Screw: 步骤 2 中的图像 1,2 Giant Reign 2 Wheel Spoke Replacement, Axle Screw: 步骤 2 中的图像 2,2
    • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
    • Push the axle screw to reveal the axle rod on the other side.
    询问修复机器人
    添加评论
  3. Giant Reign 2 Wheel Spoke Replacement: 步骤 3 中的图像 1,1
    • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
    • Hold the wheel when pulling out the axle rod so that the bike does not fall.
    询问修复机器人
    添加评论
  4. Giant Reign 2 Wheel Spoke Replacement, Front Wheel: 步骤 4 中的图像 1,1
    • Pull the wheel from the fork.
    询问修复机器人
    添加评论
  5. Giant Reign 2 Wheel Spoke Replacement, Tire Valve: 步骤 5 中的图像 1,3 Giant Reign 2 Wheel Spoke Replacement, Tire Valve: 步骤 5 中的图像 2,3 Giant Reign 2 Wheel Spoke Replacement, Tire Valve: 步骤 5 中的图像 3,3
    • Twist and pull off the cap covering the tire valve
    • Twist off the spacer that holds the valve in place.
    • Push valve in toward wheel to release air pressure.
    询问修复机器人
    添加评论
  6. Giant Reign 2 Wheel Spoke Replacement, Tire Rim: 步骤 6 中的图像 1,3 Giant Reign 2 Wheel Spoke Replacement, Tire Rim: 步骤 6 中的图像 2,3 Giant Reign 2 Wheel Spoke Replacement, Tire Rim: 步骤 6 中的图像 3,3
    • Insert one tire lever between the tire and the rim.
    • Push down on the tire lever until the edge of the tire is higher than the edge of the rim.
    • Insert a second tire lever next to the first.
    • Slowly slide one tire lever around the rim until the tire is released from the rim.
    询问修复机器人
    添加评论
  7. Giant Reign 2 Wheel Spoke Replacement, Tire Tube: 步骤 7 中的图像 1,1
    • Using your hand, pull the tube completely out of the tire.
    询问修复机器人
    添加评论
  8. Giant Reign 2 Wheel Spoke Replacement, Brake Rotor: 步骤 8 中的图像 1,1
    • Use an 8mm Allen wrench to unscrew the 6 (4x10mm) screws on the brake rotor.
    • Pull brake rotors off both sides of the wheel.
    添加评论
  9. Giant Reign 2 Wheel Spoke Replacement, Tire: 步骤 9 中的图像 1,1
    • Pull the tire from the rim.
    询问修复机器人
    添加评论
  10. Giant Reign 2 Wheel Spoke Replacement, Rim Tape: 步骤 10 中的图像 1,1
    • Using a tire lever, push the rim tape aside to reveal the spoke nipple.
    • Using your fingers, pull off the old spoke nipple.
    询问修复机器人
    添加评论
  11. Giant Reign 2 Wheel Spoke Replacement, Wheel Spoke: 步骤 11 中的图像 1,1
    • Push out the old spoke from the hub.
    询问修复机器人
    添加评论
  12. Giant Reign 2 Wheel Spoke Replacement: 步骤 12 中的图像 1,2 Giant Reign 2 Wheel Spoke Replacement: 步骤 12 中的图像 2,2
    • Insert a new 250mm spoke into the hub.
    • Align the spoke with the spoke nipple in the rim.
    • Try to keep the spoke as straight as possible when threading it around the other spokes. Slight bends will be taken out when it is tightened.
    询问修复机器人
    添加评论
  13. Giant Reign 2 Wheel Spoke Replacement: 步骤 13 中的图像 1,1
    • Using an SW-1 spoke wrench, tighten the spoke.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team 9-14, Amido Fall 2012 Cal Poly, Team 9-14, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G14
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 29
总计 2,829
