跳转到主内容
加入维修社区 - 创建账户
Generic DualShock 2 Cable Pinout
你所需要的
    1. Generic DualShock 2 Cable Pinout, DualShock 2 Disassembly: 步骤 1 中的图像 1,2 Generic DualShock 2 Cable Pinout, DualShock 2 Disassembly: 步骤 1 中的图像 2,2
      • First, check that the connection port of your controller (whether wireless or not) has all the pins.
      • If you have a wired controller (a controller with a cable that connects directly to your console) try bending it in different directions. This may reconnect broken connections within the controller cable and could be a temporary fix.
      添加评论
    2. Generic DualShock 2 Cable Pinout: 步骤 2 中的图像 1,2 Generic DualShock 2 Cable Pinout: 步骤 2 中的图像 2,2
      • Flip Over Controller and remove all 6 screws from the bottom of the controller.
      询问修复机器人
      添加评论
    3. Generic DualShock 2 Cable Pinout: 步骤 3 中的图像 1,2 Generic DualShock 2 Cable Pinout: 步骤 3 中的图像 2,2
      • Once the screws are removed, carefully pry the controller open with your hands.
      • Remove the screw holding the circuit board in place.
      询问修复机器人
      添加评论
    4. Generic DualShock 2 Cable Pinout: 步骤 4 中的图像 1,1
      • Carefully remove the circuit board from the front cover of the controller.
      添加评论
    5. Generic DualShock 2 Cable Pinout: 步骤 5 中的图像 1,1
      • Analyze the rubber pads for any debris that may be getting in the way of the black pads. These make an electrical connection on the pad and may not be contacting properly.
      询问修复机器人
      添加评论
    6. Generic DualShock 2 Cable Pinout: 步骤 6 中的图像 1,1
      • Examine the flexible trigger board itself for any dirt or debris that could get in the rubber button pad's way.
      询问修复机器人
      添加评论
    7. Generic DualShock 2 Cable Pinout: 步骤 7 中的图像 1,1
      • Check the connection of the flexible trigger board to the main circuit board of your controller.
      询问修复机器人
      添加评论
    8. Generic DualShock 2 Cable Pinout: 步骤 8 中的图像 1,1
      • If the previous steps are all covered and you are still facing difficulties in getting your buttons to work, consider replacing the main circuit board or flexible trigger board.
      询问修复机器人
      添加评论
    9. Generic DualShock 2 Cable Pinout: 步骤 9 中的图像 1,1
      • Reverse the disassembly steps until the controller is back to its original state. Plug the controller into the console and test whether the fix worked.
      询问修复机器人
      添加评论
    1. Generic DualShock 2 Cable Pinout, Cable Color And Order: 步骤 10 中的图像 1,2 Generic DualShock 2 Cable Pinout, Cable Color And Order: 步骤 10 中的图像 2,2
      • Here it is how it should be connected.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Bruno Melo
于02/07/19注册
178 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 104
过去 30 天: 395
总计 11,407
