跳转到主内容
加入维修社区 - 创建账户
General Electric Create Jason Wu Power Supply Button Replacement
你所需要的
    1. General Electric Create Jason Wu Power Supply Button Replacement, General Electric Create Jason Wu Casing Disassembly: 步骤 1 中的图像 1,3 General Electric Create Jason Wu Power Supply Button Replacement, General Electric Create Jason Wu Casing Disassembly: 步骤 1 中的图像 2,3 General Electric Create Jason Wu Power Supply Button Replacement, General Electric Create Jason Wu Casing Disassembly: 步骤 1 中的图像 3,3
      • Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
      • These screws were missing in our example. These screws should have been small Phillips PH000 screws 1.5mm in length.
      • These screws are very small. To keep from losing any pieces, place all small metals on a magnetic project mat.
      询问修复机器人
      添加评论
    2. General Electric Create Jason Wu Power Supply Button Replacement: 步骤 2 中的图像 1,2 General Electric Create Jason Wu Power Supply Button Replacement: 步骤 2 中的图像 2,2
      • After the screws are removed, pull the front casing up and away from the camera.
      • If the casing is difficult to remove, use a plastic opening tool to gently pry up on the front as shown.
      询问修复机器人
      添加评论
    3. General Electric Create Jason Wu Power Supply Button Replacement: 步骤 3 中的图像 1,3 General Electric Create Jason Wu Power Supply Button Replacement: 步骤 3 中的图像 2,3 General Electric Create Jason Wu Power Supply Button Replacement: 步骤 3 中的图像 3,3
      • Using your hands or an opening tool, pry off the silver frame, taking special care at the top of the camera where the buttons are as it is a little harder to pry off.
      • If the back casing is loose from the camera body, it may be easier to perform step 4 first, then accomplish this step. Proceed as your unit allows.
      询问修复机器人
      添加评论
    4. General Electric Create Jason Wu Power Supply Button Replacement: 步骤 4 中的图像 1,3 General Electric Create Jason Wu Power Supply Button Replacement: 步骤 4 中的图像 2,3 General Electric Create Jason Wu Power Supply Button Replacement: 步骤 4 中的图像 3,3
      • The last part of the casing to disconnect is the back that houses the LCD screen.
      • The screen is attached by a connection ribbon. Gently pull the casing and screen away from the camera body to disconnect the casing.
      • The LCD screen is held onto the back casing by a small amount of adhesive. This may come loose during this process. Do not worry if they become separated.
      • This plug and the connection ribbon are fragile, try not to tear the connection ribbon when disconnecting.
      询问修复机器人
      添加评论
    1. General Electric Create Jason Wu Power Supply Button Replacement, Power Supply Button: 步骤 5 中的图像 1,3 General Electric Create Jason Wu Power Supply Button Replacement, Power Supply Button: 步骤 5 中的图像 2,3 General Electric Create Jason Wu Power Supply Button Replacement, Power Supply Button: 步骤 5 中的图像 3,3
      在这个步骤中使用的工具:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      • Locate the metal frame removed from around the camera in step 3.
      • Lay the frame button side down or flat and gently pry the button out of place with the 3.0 flathead bit or a pair of tweezers.
      • This is very brittle plastic so use extreme caution and minimal force.
      • The button is secured to the frame by two small black rods pushed into the white colored portion of the button (see picture).
      询问修复机器人
      添加评论
    2. General Electric Create Jason Wu Power Supply Button Replacement: 步骤 6 中的图像 1,1
      • The button will pry off easily and shouldn't take much force
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 25
总计 588
