跳转到主内容
加入维修社区 - 创建账户
General Electric Create Jason Wu Internal Memory Card Replacement
你所需要的
  1. General Electric Create Jason Wu Internal Memory Card Replacement, General Electric Create Jason Wu Casing Disassembly: 步骤 1 中的图像 1,3 General Electric Create Jason Wu Internal Memory Card Replacement, General Electric Create Jason Wu Casing Disassembly: 步骤 1 中的图像 2,3 General Electric Create Jason Wu Internal Memory Card Replacement, General Electric Create Jason Wu Casing Disassembly: 步骤 1 中的图像 3,3
    • Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
    • These screws were missing in our example. These screws should have been small Phillips PH000 screws 1.5mm in length.
    • These screws are very small. To keep from losing any pieces, place all small metals on a magnetic project mat.
    询问修复机器人
    添加评论
  2. General Electric Create Jason Wu Internal Memory Card Replacement: 步骤 2 中的图像 1,2 General Electric Create Jason Wu Internal Memory Card Replacement: 步骤 2 中的图像 2,2
    • After the screws are removed, pull the front casing up and away from the camera.
    • If the casing is difficult to remove, use a plastic opening tool to gently pry up on the front as shown.
    询问修复机器人
    添加评论
  3. General Electric Create Jason Wu Internal Memory Card Replacement: 步骤 3 中的图像 1,3 General Electric Create Jason Wu Internal Memory Card Replacement: 步骤 3 中的图像 2,3 General Electric Create Jason Wu Internal Memory Card Replacement: 步骤 3 中的图像 3,3
    • Using your hands or an opening tool, pry off the silver frame, taking special care at the top of the camera where the buttons are as it is a little harder to pry off.
    • If the back casing is loose from the camera body, it may be easier to perform step 4 first, then accomplish this step. Proceed as your unit allows.
    询问修复机器人
    添加评论
  4. General Electric Create Jason Wu Internal Memory Card Replacement: 步骤 4 中的图像 1,3 General Electric Create Jason Wu Internal Memory Card Replacement: 步骤 4 中的图像 2,3 General Electric Create Jason Wu Internal Memory Card Replacement: 步骤 4 中的图像 3,3
    • The last part of the casing to disconnect is the back that houses the LCD screen.
    • The screen is attached by a connection ribbon. Gently pull the casing and screen away from the camera body to disconnect the casing.
    • The LCD screen is held onto the back casing by a small amount of adhesive. This may come loose during this process. Do not worry if they become separated.
    • This plug and the connection ribbon are fragile, try not to tear the connection ribbon when disconnecting.
    询问修复机器人
    添加评论
  5. General Electric Create Jason Wu Internal Memory Card Replacement, General Electric Create Jason Wu Interior Disassembly: 步骤 5 中的图像 1,3 General Electric Create Jason Wu Internal Memory Card Replacement, General Electric Create Jason Wu Interior Disassembly: 步骤 5 中的图像 2,3 General Electric Create Jason Wu Internal Memory Card Replacement, General Electric Create Jason Wu Interior Disassembly: 步骤 5 中的图像 3,3
    • After the casing is removed, use your fingers to carefully lift up on the rubber pad, if it didn't already fall out during step 4.
    • The pad isn't secured to the camera so it will lift up and pull away easily.
    • After the pad is removed, the 2 Phillips head screws holding the control board will be exposed.
    询问修复机器人
    添加评论
  6. General Electric Create Jason Wu Internal Memory Card Replacement: 步骤 6 中的图像 1,3 General Electric Create Jason Wu Internal Memory Card Replacement: 步骤 6 中的图像 2,3 General Electric Create Jason Wu Internal Memory Card Replacement: 步骤 6 中的图像 3,3
    • Using the Phillips precision screwdriver with the PH000 Phillips bit, remove the two 1.5mm screws.
    • Although the 2 screws are removed, the button board is still attached with a connection ribbon.
    • With a firm grip towards the bottom of the control board, gently pull away from the camera, removing the ribbon from the connector.
    询问修复机器人
    添加评论
  7. General Electric Create Jason Wu Internal Memory Card Replacement: 步骤 7 中的图像 1,3 General Electric Create Jason Wu Internal Memory Card Replacement: 步骤 7 中的图像 2,3 General Electric Create Jason Wu Internal Memory Card Replacement: 步骤 7 中的图像 3,3
    • Locate the six 1.5mm Phillips screws that are holding on the interior camera frame.
    • Using the Phillips precision screwdriver and the PH000 Phillips bit, remove the 6 screws.
    • With the screws removed, the interior frame will no longer be fastened to the camera body and can be lifted up and away.
    询问修复机器人
    添加评论
  8. General Electric Create Jason Wu Internal Memory Card Replacement, Internal Memory Card: 步骤 8 中的图像 1,3 General Electric Create Jason Wu Internal Memory Card Replacement, Internal Memory Card: 步骤 8 中的图像 2,3 General Electric Create Jason Wu Internal Memory Card Replacement, Internal Memory Card: 步骤 8 中的图像 3,3
    • Locate the memory card slot in the bottom right corner of the camera.
    • Using a plastic opening tool, gently pry up on the edges of the bottom right corner of the control board.
    • Gently raise the lower right corner of the circuit board by prying upwards with an opening tool.
    询问修复机器人
    添加评论
  9. General Electric Create Jason Wu Internal Memory Card Replacement: 步骤 9 中的图像 1,2 General Electric Create Jason Wu Internal Memory Card Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Using a pair of precision tweezers, slide one end under the memory card.
    • Firmly grip the memory card with the tweezers and pull directly outwards.
    • The tweezers may not be necessary in this step and the memory card may be removed by hand using a finger nail.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 34
总计 746
