跳转到主内容
加入维修社区 - 创建账户
GeeksPhone Keon Battery Replacement
你所需要的
  1. GeeksPhone Keon Battery Replacement, Battery: 步骤 1 中的图像 1,2 GeeksPhone Keon Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
    询问修复机器人
    添加评论
  2. GeeksPhone Keon Battery Replacement: 步骤 2 中的图像 1,1
    • Lift the cover away from the phone.
    询问修复机器人
    添加评论
  3. GeeksPhone Keon Battery Replacement: 步骤 3 中的图像 1,1
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
USF Tampa, Team 3-5, Eyestone Fall 2015 USF Tampa, Team 3-5, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S3G5
4 名成员
创作了24篇指南
4指南评论
Newer Keon model has user replaceable battery GP-BA002
gintasdx - 回复 分享
Newer Keon model has a user replaceable battery Li-ion GP-BA002 3.7V 1580mAh .
gintasdx - 回复 分享
GP-BA002: Li-ion, 3.7V ,1580mAh, Limited charge voltage 4.2v, with dimensions: 5.1x5.1x0.5cm, its a four pin battery, the pinout es: Negative, BSI, BTemp, Positive, both negative and positive al labeled on the front of the batery the other two not, BTemp is a 10k oms resistor and BSI reads 47k oms on a discharged battery
Diego Gomez - 回复 分享
Has anybody found another battery that is compatible with the GP-BA002?
ecloud - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 36
总计 1,057
