简介
This repair is needed in situations where your keyboard stops working. If you have checked that all the keys are properly seated and that there is nothing blocking key movement, replacing the keyboard should correct the issue.
你所需要的
Slide the locking switch towards the open lock picture.
Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
Once the laptop is disengaged, completely remove the battery from the laptop.
Remove a 4mm Phillips #0 screw just beneath the battery that holds the speaker cover panel.
Carefully pry up on the right and left sides of the speaker cover panel.
Gently pry up on the corners of the keyboard with the plastic opening tool to free the keyboard.
Pull on the cord connecting the keyboard to the computer until it slides out.
3等其他人完成本指南。
