跳转到主内容
加入维修社区 - 创建账户
Gateway W350I Display Replacement
你所需要的
  1. Gateway W350I Display Replacement, Battery Access: 步骤 1 中的图像 1,1
    • Turn the laptop upside down and position it as shown in the image.
    询问修复机器人
    添加评论
  2. Gateway W350I Display Replacement, Unlocking the Battery: 步骤 2 中的图像 1,3 Gateway W350I Display Replacement, Unlocking the Battery: 步骤 2 中的图像 2,3 Gateway W350I Display Replacement, Unlocking the Battery: 步骤 2 中的图像 3,3
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
    询问修复机器人
    添加评论
  3. Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: 步骤 3 中的图像 1,2 Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: 步骤 3 中的图像 2,2
    • Pry the six black rubber protectors out of the screw holes.
    • Remove all six of the 4mm Phillips #0 screws that were covered by the rubber protectors.
    添加评论
  4. Gateway W350I Display Replacement, Separate Plastic Casing: 步骤 4 中的图像 1,2 Gateway W350I Display Replacement, Separate Plastic Casing: 步骤 4 中的图像 2,2
    • Separate the plastic screen casing from the laptop lid by inserting a plastic opening tool. Complete this step around the top and along both sides of the screen.
    添加评论
  5. Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: 步骤 5 中的图像 1,2 Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: 步骤 5 中的图像 2,2
    • Remove the two 4mm Phillips #0 screws located at the top that fasten the screen bracket to the laptop.
    询问修复机器人
    添加评论
  6. Gateway W350I Display Replacement, Remove LCD Screen from Bracket: 步骤 6 中的图像 1,1
    • Separate the bracket and the screen from its original position within the lid of the laptop.
    • Remove the four 4mm Phillips #0 screws on the sides of the bracket that hold the LCD screen.
    询问修复机器人
    添加评论
  7. Gateway W350I Display Replacement, Remove Video Cable: 步骤 7 中的图像 1,2 Gateway W350I Display Replacement, Remove Video Cable: 步骤 7 中的图像 2,2
    • Detach the video cable that is attached to the laptop from the back of the screen.
    • Be careful while removing the video cable as it is very delicate.
    添加评论
  8. Gateway W350I Display Replacement: 步骤 8 中的图像 1,2 Gateway W350I Display Replacement: 步骤 8 中的图像 2,2
    • Disconnect the camera connector from the circuit board to completely free the screen.
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
USF Tampa, Team 4-1, Brown Fall 2014 USF Tampa, Team 4-1, Brown Fall 2014 的会员
USFT-BROWN-F14S4G1
3 名成员
创作了10篇指南
1指南评论
It was very easy to follow.
Very friendly guide.
stewilli - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 31
总计 1,736
