跳转到主内容
加入维修社区 - 创建账户
Gateway NV52 Keyboard Replacement
你所需要的
  1. Gateway NV52 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop on its backside with the stickers and barcode facing you.
    • Locate the latches on the top left corner.
    询问修复机器人
    添加评论
  2. Gateway NV52 Keyboard Replacement: 步骤 2 中的图像 1,1
    • In order to unlock the battery, slide the vertical latch downward where it indicates the unlocking icon.
    询问修复机器人
    添加评论
  3. Gateway NV52 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Slide the horizontal latch to the right to pop open the battery pack.
    询问修复机器人
    添加评论
  4. Gateway NV52 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Remove the five identical 9/32" Phillips Screws located under the battery and both upper corners using the Phillips #0 Screwdriver.
    询问修复机器人
    添加评论
  5. Gateway NV52 Keyboard Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    Heavy-Duty Spudger
    • Flip the Device so the keyboard and display screen are faced upright.
    • Lift up the media button board cover using the Heavy Duty Spudger. Apply a minimum amount of upward force to the media button board cover at the right bottom corner. Starting from the right, continuously lift the cover to the left edge until completely separated.
    • Do not lift up the media button board cover too much, it’s still connected to the motherboard. Set the media button board cover upside down on the keyboard.
    询问修复机器人
    添加评论
  6. Gateway NV52 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Disconnect the dark colored locking tab by pulling at a 90 degree angle, and then slightly pull away the ribbon from the locking tab.
    询问修复机器人
    添加评论
  7. Gateway NV52 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Lift up the keyboard with the Spudger. Rotate the keyboard until its faced down on top of its base.
    • The keyboard is still connected to the access keyboard connector, so do not attempt to detach the keyboard from the laptop, yet.
    添加评论
  8. Gateway NV52 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Disconnect the brown-colored locking tab by pulling at a 90 degree angle and slightly pulling away from the locking tab.
    • Do not apply too much force to the locking tab, because a damaged connector will disable the keyboard.
    • Remove the keyboard, and placed it in a safe and dry place.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Tim En
于01/26/13注册
557 声望
创作了4篇指南
团队
Cal Poly, Team 7-24, Regan Spring 2014 Cal Poly, Team 7-24, Regan Spring 2014 的会员
CPSU-REGAN-S14S7G24
4 名成员
创作了18篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 40
总计 2,693
