跳转到主内容
加入维修社区 - 创建账户
Gateway Lt4004u Keyboard Replacement
你所需要的
  1. Gateway Lt4004u Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 Gateway Lt4004u Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 Gateway Lt4004u Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Place the laptop face down in front of you.
    • Locate the battery lock switches on the left and right top corners of the bottom of the device indicated by the red circles.
    • Pinch the switches and slide toward the edges of the computer to unlock.
    询问修复机器人
    添加评论
  2. Gateway Lt4004u Keyboard Replacement: 步骤 2 中的图像 1,2 Gateway Lt4004u Keyboard Replacement: 步骤 2 中的图像 2,2
    • Once the switches have both been unlocked, push the battery upwards away from the rest of the laptop.
    • Remove the battery from the laptop.
    询问修复机器人
    添加评论
  3. Gateway Lt4004u Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,3 Gateway Lt4004u Keyboard Replacement, Keyboard: 步骤 3 中的图像 2,3 Gateway Lt4004u Keyboard Replacement, Keyboard: 步骤 3 中的图像 3,3
    • Open the laptop so that the screen and keyboard are facing you.
    • Identify the 5 tabs above the function keys in the crevice that attaches the keyboard to the main frame.
    询问修复机器人
    添加评论
  4. Gateway Lt4004u Keyboard Replacement: 步骤 4 中的图像 1,3 Gateway Lt4004u Keyboard Replacement: 步骤 4 中的图像 2,3 Gateway Lt4004u Keyboard Replacement: 步骤 4 中的图像 3,3
    • Use an opening pick to push each tab away from you.
    • Use an opening tool to push the middle tab until you hear a click. Begin to push the tool downward into the computer and slide the card along the length of the keyboard, as you overcome the five tabs.
    • A clicking sound is normal and no cause for alarm.
    询问修复机器人
    添加评论
  5. Gateway Lt4004u Keyboard Replacement: 步骤 5 中的图像 1,3 Gateway Lt4004u Keyboard Replacement: 步骤 5 中的图像 2,3 Gateway Lt4004u Keyboard Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • Begin to slide the plastic card under the top edge of the keyboard. You will hear popping sounds and the keyboard will eventually be released.
    • Carefully pry the keyboard from the main frame, starting at the top section.
    • Look at the intel sticker in this step and the next to orient your computer with the pictures.
    添加评论
  6. Gateway Lt4004u Keyboard Replacement: 步骤 6 中的图像 1,2 Gateway Lt4004u Keyboard Replacement: 步骤 6 中的图像 2,2
    • Look at the intel sticker in this step and the previous step to orient your computer with the pictures.
    • Unplug the thin blue connection piece beneath the keyboard. It may pop off on its own while you are prying off the keyboard.
    • The popping noise will not hurt the computer.
    • Once the thin blue plastic has been detached, remove the keyboard from the rest of the laptop.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
Clemson, Team 6-5, Benson Spring 2016 Clemson, Team 6-5, Benson Spring 2016 的会员
CLEM-BENSON-S16S6G5
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 27
总计 900
