跳转到主内容
加入维修社区 - 创建账户
Garmin inReach Mini Battery Replacement
你所需要的
    1. Garmin inReach Mini Battery Replacement, Nylon Strap: 步骤 1 中的图像 1,1
      • Place the device on a level surface with the back hard case facing up.
      询问修复机器人
      添加评论
    2. Garmin inReach Mini Battery Replacement: 步骤 2 中的图像 1,3 Garmin inReach Mini Battery Replacement: 步骤 2 中的图像 2,3 Garmin inReach Mini Battery Replacement: 步骤 2 中的图像 3,3
      • Use the T5 to remove the 1.9mm screw attached to the nylon strap.
      • Remove the nylon strap.
      询问修复机器人
      添加评论
    1. Garmin inReach Mini Battery Replacement, Back Case: 步骤 3 中的图像 1,3 Garmin inReach Mini Battery Replacement, Back Case: 步骤 3 中的图像 2,3 Garmin inReach Mini Battery Replacement, Back Case: 步骤 3 中的图像 3,3
      • Remove the five 1.8 mm screws located on the top, sides, and bottom corners of the backside of the device.
      添加评论
    2. Garmin inReach Mini Battery Replacement: 步骤 4 中的图像 1,3 Garmin inReach Mini Battery Replacement: 步骤 4 中的图像 2,3 Garmin inReach Mini Battery Replacement: 步骤 4 中的图像 3,3
      • Lastly, lift the protective cap on the side of the device that states "SOS". Slowly pull it to the right in order to remove the back hard case.
      询问修复机器人
      添加评论
    3. Garmin inReach Mini Battery Replacement: 步骤 5 中的图像 1,3 Garmin inReach Mini Battery Replacement: 步骤 5 中的图像 2,3 Garmin inReach Mini Battery Replacement: 步骤 5 中的图像 3,3
      在这个步骤中使用的工具:
      • Using the precision tweezers with the round tips, detach the battery connector from the motherboard.
      • Disconnecting the battery stops the flow of power into the motherboard. This is for your own safety.
      • If utilizing this guide as a prerequisite to replacing the motherboard, it is crucial not to damage the cable connecting the battery to the motherboard. When the new motherboard is introduced, it will need to be reconnected with that cable.
      询问修复机器人
      添加评论
    1. Garmin inReach Mini Battery Replacement, Battery: 步骤 6 中的图像 1,3 Garmin inReach Mini Battery Replacement, Battery: 步骤 6 中的图像 2,3 Garmin inReach Mini Battery Replacement, Battery: 步骤 6 中的图像 3,3
      • After removing the back hard case, users can access the battery on the inside of the back hard case.
      • Take the iFixit opening tool and insert it into the small crevices on each side of the battery. Once inserted, apply pressure downward in order to lift the battery up. Repeat on all 3 corners.
      询问修复机器人
      添加评论
    2. Garmin inReach Mini Battery Replacement: 步骤 7 中的图像 1,2 Garmin inReach Mini Battery Replacement: 步骤 7 中的图像 2,2
      • Create leverage by inserting the opening tool underneath the battery. Lift the battery up until it detaches from the case, then remove the battery entirely.
      询问修复机器人
      添加评论
    3. Garmin inReach Mini Battery Replacement: 步骤 8 中的图像 1,1
      在这个步骤中使用的工具:
      • Then using the precision tweezers with the round tips, lightly pull the battery out from the case.
      • The battery is attached to the back hard case with an adhesive.
      • Dispose of the lithium ion battery in a safe manner in order to prevent electrical hazards. Keep the battery dry and cool.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
2指南评论
Any idea where to buy a replacement motherboard? The battery in mine corroded and the battery connector broke off.
Ashley Hill - 回复 分享
where to buy the battery from? is it the same battery for Garmin inReach Mini 2?
Akkad - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 37
过去 30 天: 143
总计 7,468
