当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
Gently push the strap's pin out. It will begin to protrude from the other end.
Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
Follow previous guides until you've exposed the battery as shown.
Begin by removing the battery connector tab.
Be sure not to use a metal implement or your fingers to remove this tab. Doing so may cause personal harm or damage to the electrical components.
Use a plastic opening pick to gently pry out the battery as shown.
The battery is Lithium Polymer, follow safe handling procedures and DO NOT deform it upon removal.
With the battery loose from the case, rotate it to expose the attached tab
Gently pry up the attached tab with a fingernail.
Keep the vibrator, circled in red, as you may need to solder it to the new battery upon re-installation later.
Use the spudger to pry up the board from the case.
Insert the spudger a minimum distance beneath the board as there are components below.
Wiggle the exposed side of the board from each end until it comes free.
Use proper electrostatic discharge safety when removing and handling the board.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
