跳转到主内容
加入维修社区 - 创建账户
Garmin Vívoactive 4 Button Replacement
你所需要的
  1. Garmin Vívoactive 4 Button Replacement, Watch Band: 步骤 1 中的图像 1,1
    • Flip the watch on its back to reveal the watch band connection pins.
    询问修复机器人
  2. Garmin Vívoactive 4 Button Replacement, Remove Bands: 步骤 2 中的图像 1,3 Garmin Vívoactive 4 Button Replacement, Remove Bands: 步骤 2 中的图像 2,3 Garmin Vívoactive 4 Button Replacement, Remove Bands: 步骤 2 中的图像 3,3
    • Wedge your fingernail or the tip of a spudger underneath the watch band's small metal pin.
    • Push on the pin to release the strap from it's hinge.
    • Pull the strap away from the watch to disconnect it.
    • The strap will not pull away if the pin isn't fully pushed in.
    询问修复机器人
  3. Garmin Vívoactive 4 Button Replacement: 步骤 3 中的图像 1,1
    • With both straps removed, a new replacement watch band may be inserted.
    询问修复机器人
  4. Garmin Vívoactive 4 Button Replacement, Screen: 步骤 4 中的图像 1,1
    • Use a heatgun to loosen the adhesive beneath the screen, it should take a 5-10 minutes for adhesive to loosen.
    • Handle the watch with care to avoid burning yourself after it has been heated. Review the How to Use a Heat Gun to Soften Adhesive guide.
  5. Garmin Vívoactive 4 Button Replacement: 步骤 5 中的图像 1,2 Garmin Vívoactive 4 Button Replacement: 步骤 5 中的图像 2,2
    • Wedge a thin opening tool or your iFixit Jimmy in between the seam where the screen and the watch’s housing connect.
    • Pry the screen off the device.
    • There is a cable underneath the screen that needs to be disconnected - be careful not to rip it.
    • Work quickly so the adhesive doesn’t cool too much.
    询问修复机器人
  6. Garmin Vívoactive 4 Button Replacement: 步骤 6 中的图像 1,3 Garmin Vívoactive 4 Button Replacement: 步骤 6 中的图像 2,3 Garmin Vívoactive 4 Button Replacement: 步骤 6 中的图像 3,3
    • Carefully disconnect both cables from the motherboard by placing the tip of your spudger under the edge of the connector, and prying the connector straight up from its socket.
    询问修复机器人
  7. Garmin Vívoactive 4 Button Replacement: 步骤 7 中的图像 1,1
    • Remove the screen.
    询问修复机器人
  8. Garmin Vívoactive 4 Button Replacement, Motherboard: 步骤 8 中的图像 1,1
    • Carefully peel off the ribbon tape that is holding down the motherboard.
    询问修复机器人
  9. Garmin Vívoactive 4 Button Replacement: 步骤 9 中的图像 1,1
    • Place the tip of your spudger under the edge of the connector, and pry the connector straight up from its socket to disconnect the battery from the motherboard.
    • Do this carefully to avoid ripping the cable.
    询问修复机器人
  10. Garmin Vívoactive 4 Button Replacement: 步骤 10 中的图像 1,3 Garmin Vívoactive 4 Button Replacement: 步骤 10 中的图像 2,3 Garmin Vívoactive 4 Button Replacement: 步骤 10 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the 3.2 mm screw on the motherboard.
    • Use a Phillips #00 screwdriver to remove the 4.8 mm screw on the motherboard.
    询问修复机器人
  11. Garmin Vívoactive 4 Button Replacement: 步骤 11 中的图像 1,3 Garmin Vívoactive 4 Button Replacement: 步骤 11 中的图像 2,3 Garmin Vívoactive 4 Button Replacement: 步骤 11 中的图像 3,3
    • Pull the battery cable up to dislodge the motherboard.
    • Gently remove the motherboard from the socket.
    • The motherboard may get caught under the housing due to the clips on the edge.
    询问修复机器人
  12. Garmin Vívoactive 4 Button Replacement, Battery: 步骤 12 中的图像 1,2 Garmin Vívoactive 4 Button Replacement, Battery: 步骤 12 中的图像 2,2
    • Use the pointed tip of a spudger to carefully push on each side of the battery connector to disconnect the battery from the motherboard.
  13. Garmin Vívoactive 4 Button Replacement: 步骤 13 中的图像 1,3 Garmin Vívoactive 4 Button Replacement: 步骤 13 中的图像 2,3 Garmin Vívoactive 4 Button Replacement: 步骤 13 中的图像 3,3
    • Use a spudger to pry the battery from the case.
    • Be careful not to damage any surrounding components.
    • There is an adhesive holding the battery down. Use an iOpener if it is too difficult to remove the battery with the spudger alone.
  14. Garmin Vívoactive 4 Button Replacement, Button: 步骤 14 中的图像 1,3 Garmin Vívoactive 4 Button Replacement, Button: 步骤 14 中的图像 2,3 Garmin Vívoactive 4 Button Replacement, Button: 步骤 14 中的图像 3,3
    • Wedge a spudger or your iFixit Jimmy in between the button's snap ring and the watch housing.
    • Carefully pry the snap ring off the button.
    • Remove the button and components from the watch housing.
    询问修复机器人
结论
Bryan Chavez
于11/01/23注册
380 声望
创作了4篇指南
团队
UMass Dartmouth, Team 1-3, Petersen Fall 2023 UMass Dartmouth, Team 1-3, Petersen Fall 2023 的会员
UMASSD-PETERSEN-F23S1G3
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 50
总计 993
