跳转到主内容
加入维修社区 - 创建账户
Garmin Nuvi 65LM Screen Replacement
你所需要的
    1. Garmin Nuvi 65LM Screen Replacement, Plastic device casing: 步骤 1 中的图像 1,2 Garmin Nuvi 65LM Screen Replacement, Plastic device casing: 步骤 1 中的图像 2,2
      • Place the device on a flat surface with the screen facing down.
      • Remove the four 4.80 mm T5 screws on the corners of the device with a T5 Torx screwdriver.
      询问修复机器人
      添加评论
    2. Garmin Nuvi 65LM Screen Replacement: 步骤 2 中的图像 1,2 Garmin Nuvi 65LM Screen Replacement: 步骤 2 中的图像 2,2
      • There is a ribbon cable that will still connect the front and back panels once they are pried part.
      • Use the plastic opening tool to gently pry apart the front and back casing panels. Repeat this at multiple locations around the edge of the device. You should hear the clips that hold the front and back together pop apart.
      • Once there is a large gap between the from and back casing panels, use your hands to separate the two halves.
      询问修复机器人
      添加评论
    3. Garmin Nuvi 65LM Screen Replacement: 步骤 3 中的图像 1,3 Garmin Nuvi 65LM Screen Replacement: 步骤 3 中的图像 2,3 Garmin Nuvi 65LM Screen Replacement: 步骤 3 中的图像 3,3
      • Use a spudger to pop up the ZIF connector tab that fastens the ribbon cable to the motherboard.
      • Gently pull the front panel away and set it on your flat work surface.
      询问修复机器人
      添加评论
    1. Garmin Nuvi 65LM Screen Replacement, Screen: 步骤 4 中的图像 1,2 Garmin Nuvi 65LM Screen Replacement, Screen: 步骤 4 中的图像 2,2
      • Use the flat end the spudger to push back the casing clips that hold the screen onto the front casing.
      • Apply light pressure to the front of the screen as you push the casing clips back. This will keep the clips from clicking back into place.
      • Once all clips are pushed back, the screen will easily lift away from the front casing panel.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 15-3, Amido Spring 2015 Cal Poly, Team 15-3, Amido Spring 2015 的会员
CPSU-AMIDO-S15S15G3
4 名成员
创作了24篇指南
1指南评论
Hi where I can get nuvi65lmt screen
ganesh bhattarai - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 27
总计 2,370
