跳转到主内容
加入维修社区 - 创建账户
Garmin Nuvi 2599 Display Replacement
你所需要的
    1. Garmin Nuvi 2599 Display Replacement, Display: 步骤 1 中的图像 1,2 Garmin Nuvi 2599 Display Replacement, Display: 步骤 1 中的图像 2,2
      • Use a T4 Torx screwdriver to remove the four 5.8 mm screws from the back of the device.
      询问修复机器人
      添加评论
    2. Garmin Nuvi 2599 Display Replacement: 步骤 2 中的图像 1,2 Garmin Nuvi 2599 Display Replacement: 步骤 2 中的图像 2,2
      • Insert an opening pick into the seam between the top and bottom case and slide it around the edge of the device to release the clips holding them together.
      • Insert an opening tool into the seam between the top and bottom casing, and gently pry them apart.
      • Avoid pulling them apart, as there are cables connecting the top and bottom case.
      询问修复机器人
      添加评论
    3. Garmin Nuvi 2599 Display Replacement: 步骤 3 中的图像 1,2 Garmin Nuvi 2599 Display Replacement: 步骤 3 中的图像 2,2
      • Use an opening tool or a clean fingernail to flip up the locking flap on the display cable—this is the unlocked position.
      • Use tweezers or your fingers to gently pull the ribbon cable out of its socket.
      • Remove the display assembly.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
取消:我没有完成这个指南。
Bax Edwards
于09/25/25注册
757 声望
创作了5篇指南
团队
Texas Tech, Team 41-8, Allen Fall 2025 Texas Tech, Team 41-8, Allen Fall 2025 的会员
TTU-ALLEN-F25S41G8
3 名成员
创作了20篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 149
