跳转到主内容
加入维修社区 - 创建账户
Garmin Fenix 3 Display Assembly Replacement
你所需要的
    1. Garmin Fenix 3 Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 1,2 Garmin Fenix 3 Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 2,2
      • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
      询问修复机器人
      添加评论
    2. Garmin Fenix 3 Display Assembly Replacement: 步骤 2 中的图像 1,1
      • Carefully lift the face off the watch base.
      • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
      询问修复机器人
      添加评论
    3. Garmin Fenix 3 Display Assembly Replacement: 步骤 3 中的图像 1,1
      • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
      询问修复机器人
      添加评论
    4. Garmin Fenix 3 Display Assembly Replacement: 步骤 4 中的图像 1,1
      • Set the watch face aside.
      添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
4指南评论
Thanks Adam. How do you chgange the glass in a Fenix 3? I can strip the watch down as you have described but not sure how to replace the screen.
Richard Davies-Cooke - 回复 分享
I have the same question.
Nicolas Chartier - 回复 分享
How do you make sure ribbon connector is aligned correctly
Steven - 回复 分享
I have Fennix3, replaced the battery with new one (tested the battery before fixing), however, after complete assembly the watch does not start up? any hints?
Abdullah - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 95
总计 11,084
