跳转到主内容
加入维修社区 - 创建账户
Garmin DriveSmart 55 EX Battery Replacement
你所需要的
    1. Garmin DriveSmart 55 EX Battery Replacement, Battery: 步骤 1 中的图像 1,3 Garmin DriveSmart 55 EX Battery Replacement, Battery: 步骤 1 中的图像 2,3 Garmin DriveSmart 55 EX Battery Replacement, Battery: 步骤 1 中的图像 3,3
      • Use a T5 Torx screwdriver to remove the four 4.2 mm black screws from the back case.
      • Insert the plastic opening tool into the gap between the screen and case, and release the clips along the edges of the device.
      • Use opening picks along the perimeter to keep them separated until you can remove the screen.
      添加评论
    2. Garmin DriveSmart 55 EX Battery Replacement: 步骤 2 中的图像 1,3 Garmin DriveSmart 55 EX Battery Replacement: 步骤 2 中的图像 2,3 Garmin DriveSmart 55 EX Battery Replacement: 步骤 2 中的图像 3,3
      • Gently separate the screen from the case and place the device flat on the surface.
      • Avoid pulling on the screen too forcefully, as the display ribbon cable is still connected to the motherboard.
      • Use a T5 Torx screwdriver to remove the four 3.8 mm silver screws from the motherboard.
      • Avoid scratching the motherboard when using the screwdriver, as this can damage the device.
      • Gently pry the motherboard up using the plastic opening tool.
      询问修复机器人
      添加评论
    3. Garmin DriveSmart 55 EX Battery Replacement: 步骤 3 中的图像 1,3 Garmin DriveSmart 55 EX Battery Replacement: 步骤 3 中的图像 2,3 Garmin DriveSmart 55 EX Battery Replacement: 步骤 3 中的图像 3,3
      • Use your fingers or tweezers to disconnect the battery connector on the underside of the motherboard.
      • Avoid pulling on the cables.
      • Gently remove the battery from the casing.
      • If you're unable to get a grip on it, use the opening tool to lift it enough to get your fingers underneath.
      • Avoid bending or puncturing the battery as it can catch fire.
      添加评论
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 45
总计 184
