跳转到主内容
加入维修社区 - 创建账户
GameSir G7 SE Joystick Module Replacement
你所需要的
  1. GameSir G7 SE Joystick Module Replacement, Interior face plate: 步骤 1 中的图像 1,1
    • Remove the faceplate by prying upwards with a plastic opening tool.
    • This faceplate is magnetic and will be easy to come off.
    询问修复机器人
    添加评论
  2. GameSir G7 SE Joystick Module Replacement: 步骤 2 中的图像 1,2 GameSir G7 SE Joystick Module Replacement: 步骤 2 中的图像 2,2
    • Use a T6 Torx Screwdriver to remove the six 9 mm screws from the interior face plate.
    询问修复机器人
    添加评论
  3. GameSir G7 SE Joystick Module Replacement: 步骤 3 中的图像 1,2 GameSir G7 SE Joystick Module Replacement: 步骤 3 中的图像 2,2
    • Using a plastic spudger tool, remove the interior face plate. Go around all the edges, prying downwards until it's removed.
    • Make sure to hold the controller upside down; otherwise the buttons will fall out.
    询问修复机器人
    添加评论
  4. GameSir G7 SE Joystick Module Replacement, Joystick Module: 步骤 4 中的图像 1,1
    • Remove the plastic joystick that is covering the joystick module by pulling up on from the gray grip.
    询问修复机器人
    添加评论
  5. GameSir G7 SE Joystick Module Replacement: 步骤 5 中的图像 1,1
    • To gain access to the joystick module, you will need to gently bend the metal retention clips that hold the module in place.
    • Use a plastic spudger to gently bend the retention clips back.
    询问修复机器人
    添加评论
  6. GameSir G7 SE Joystick Module Replacement: 步骤 6 中的图像 1,1
    • Pull directly up on the joystick module to remove it from the motherboard.
    • Make sure to hold the joystick module from the red portion to prevent it from falling apart.
    添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
4指南评论
Where to get the replacement parts?
Isaiah Hackworth - 回复 分享
Where do you get the replacement parts from?
michaeljhs - 回复 分享
Guida inutile senza ricambio
Matteo Andreani - 回复 分享
Controller joystick fell apart on me. I used the video explaining the TMR sticks from gamesir to reassemble. Found this to find out I could fix it. Thank you a ton I fix it.
Devoid - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 18
过去 7 天: 132
过去 30 天: 775
总计 13,241
