跳转到主内容
加入维修社区 - 创建账户
GameSir Cyclone 2 Battery Replacement
你所需要的
  1. GameSir Cyclone 2 Battery Replacement, Face Plate: 步骤 1 中的图像 1,3 GameSir Cyclone 2 Battery Replacement, Face Plate: 步骤 1 中的图像 2,3 GameSir Cyclone 2 Battery Replacement, Face Plate: 步骤 1 中的图像 3,3
    • Flip the controller around so the back part is facing you.
    • Use a T6 Torx screwdriver to remove seven screws from the back of the controller.
    • One of the screws is hidden under the sticker. Use a pair of tweezers to lift the sticker and reveal the screw.
    询问修复机器人
    添加评论
  2. GameSir Cyclone 2 Battery Replacement: 步骤 2 中的图像 1,1
    • The screws holding the face plate are of two different lengths:
    • The two longer screws belong to the two top screw sockets on the controller.
    • The five shorter screws belong in the five bottom screw sockets, two per handle, and on in the center of on the controller.
    询问修复机器人
    添加评论
  3. GameSir Cyclone 2 Battery Replacement: 步骤 3 中的图像 1,2 GameSir Cyclone 2 Battery Replacement: 步骤 3 中的图像 2,2
    • Face the controller toward you.
    • Gently lift the face plate off the controller.
    • The d-pad and action buttons will become loose once the face plate is lifted.
    询问修复机器人
    添加评论
  4. GameSir Cyclone 2 Battery Replacement, Joystick Covers: 步骤 4 中的图像 1,3 GameSir Cyclone 2 Battery Replacement, Joystick Covers: 步骤 4 中的图像 2,3 GameSir Cyclone 2 Battery Replacement, Joystick Covers: 步骤 4 中的图像 3,3
    • Pull both joystick covers straight up to remove them from the controller.
    询问修复机器人
    添加评论
  5. GameSir Cyclone 2 Battery Replacement, Left and Right Bumpers and Triggers: 步骤 5 中的图像 1,1
    • Note the bumpers and triggers on the controller.
    询问修复机器人
    添加评论
  6. GameSir Cyclone 2 Battery Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove two screws on either side of the power button.
    • Remove the assembly that includes the power button and the top bumper buttons.
    询问修复机器人
    添加评论
  7. GameSir Cyclone 2 Battery Replacement: 步骤 7 中的图像 1,1
    • Remove the bumpers and triggers from the controller.
    询问修复机器人
    添加评论
  8. GameSir Cyclone 2 Battery Replacement, LED: 步骤 8 中的图像 1,1
    • Locate the two black boxes towards the bottom of the controller.
    • Remove these two boxes by pulling them away from the controller. They should snap right off.
    询问修复机器人
    添加评论
  9. GameSir Cyclone 2 Battery Replacement: 步骤 9 中的图像 1,1
    • Locate the LED diffusers on either side of the controller face. They are clear, cylindrical strips that help spread light from the LED beneath the black boxes removed in the previous step.
    • Lift the upper ends of each LED diffuser and remove them.
    询问修复机器人
    添加评论
  10. GameSir Cyclone 2 Battery Replacement, Battery: 步骤 10 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the four screws that secure the LED diffuser tracks.
    • Remove the LED diffuser tracks.
    询问修复机器人
    添加评论
  11. GameSir Cyclone 2 Battery Replacement: 步骤 11 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the single screw in the center of the motherboard.
    • Remove the motherboard from the controller case.
    询问修复机器人
    添加评论
  12. GameSir Cyclone 2 Battery Replacement: 步骤 12 中的图像 1,2 GameSir Cyclone 2 Battery Replacement: 步骤 12 中的图像 2,2
    • Disconnect the battery connector from the socket on the motherboard.
    • Remove the battery.
    询问修复机器人
    添加评论
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
取消:我没有完成这个指南。
另外一个人完成了本指南。
JasmineM
于10/14/25注册
373 声望
创作了4篇指南
团队
UMass Dartmouth, Team 2-6, Bowman Fall 2025 UMass Dartmouth, Team 2-6, Bowman Fall 2025 的会员
UMASSD-BOWMAN-F25S2G6
4 名成员
创作了7篇指南
2指南评论
Which battery is used there. I mean the specs so I can buy it.
Davi Ribeiro - 回复 分享
Hi @daviribeiro, we don't have the specific battery details, but it uses a 860mAh rechargeable Lithium-ion battery.
Sarah Westberg - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 62
过去 30 天: 221
总计 1,442
