跳转到主内容
加入维修社区 - 创建账户
Game Boy Advance On/Off Switch Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Game Boy Advance On/Off Switch Replacement, Remove the battery cover: 步骤 1 中的图像 1,3 Game Boy Advance On/Off Switch Replacement, Remove the battery cover: 步骤 1 中的图像 2,3 Game Boy Advance On/Off Switch Replacement, Remove the battery cover: 步骤 1 中的图像 3,3
    • Release the battery cover tab with your finger and swing the cover away from your Game Boy to remove it.
    • During reassembly, insert the tabs on the bottom edge of the cover into their cutouts and press the cover into place.
    询问修复机器人
    添加评论
  2. Game Boy Advance On/Off Switch Replacement, Remove the batteries: 步骤 2 中的图像 1,3 Game Boy Advance On/Off Switch Replacement, Remove the batteries: 步骤 2 中的图像 2,3 Game Boy Advance On/Off Switch Replacement, Remove the batteries: 步骤 2 中的图像 3,3
    • Remove the two AA batteries.
    • If the metal terminals are corroded, follow this guide to clean them.
    • When installing batteries, use the diagram in the battery well to properly orient them.
    询问修复机器人
    添加评论
  3. Game Boy Advance On/Off Switch Replacement, Remove the back shell screws: 步骤 3 中的图像 1,2 Game Boy Advance On/Off Switch Replacement, Remove the back shell screws: 步骤 3 中的图像 2,2
    • Remove the seven screws securing the back shell:
    • Six 9.4 mm‑long tri‑point Y0 screws
    • One 8.5 mm‑long JIS 1 screw
    • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping screws. Push down firmly on the driver and twist slowly.
    询问修复机器人
    添加评论
  4. Game Boy Advance On/Off Switch Replacement, Remove the back shell: 步骤 4 中的图像 1,2 Game Boy Advance On/Off Switch Replacement, Remove the back shell: 步骤 4 中的图像 2,2
    • Lift the back shell straight up and remove it.
    • During reassembly, squeeze the shell firmly around the edges and ensure the shoulder buttons and bumpers are properly seated with no large gaps. Gently test the buttons to make sure everything feels correct.
    询问修复机器人
    添加评论
  5. Game Boy Advance On/Off Switch Replacement, Remove Triggers: 步骤 5 中的图像 1,2 Game Boy Advance On/Off Switch Replacement, Remove Triggers: 步骤 5 中的图像 2,2
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels
    • For finicky or jammed triggers only! Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
    添加评论
  6. Game Boy Advance On/Off Switch Replacement, Remove the On/Off Switch: 步骤 6 中的图像 1,1
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
Adam
于01/20/10注册
907 声望
创作了6篇指南
团队
Cal Poly, Team 16-29, Maness Winter 2010 Cal Poly, Team 16-29, Maness Winter 2010 的会员
CPSU-MANESS-W10S16G29
5 名成员
创作了81篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 19
过去 30 天: 66
总计 22,565
