跳转到主内容
加入维修社区 - 创建账户
Game Boy Advance Buttons Replacement
浏览量: 3.1万
浏览统计数据:
过去24小时
11
过去 7 天:
94
过去 30 天:
367
总计
31,050
评论: 1
1 guide comment.
Go to guide comments
已完成: 15
15 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 9
9 人已收藏(并订阅)本指南。你会是下一个吗?
所需时间: 10 - 15 分钟
难度: 中等
特色指南
iFixit的工作人员认为该指南特别酷。
Follow this guide to replace, upgrade, or customize the buttons in your Nintendo Game Boy Advance model AGB-001.
This guide covers how to replace the action (A + B) buttons, shoulder (L + R) buttons, D‑pad, and ON/OFF power switch cover, as well as the side bumpers.
If you're completely re‑shelling your Game Boy, follow this guide.
The Game Boy Advance uses JIS screws. If you use a non-iFixit Phillips driver in JIS screws, you'll risk stripping them. iFixit's Phillips bits are designed to be compatible with JIS screws.
你所需要的
工具
    1. Game Boy Advance Buttons Replacement, Prepare your Game Boy for disassembly: 步骤 1 中的图像 1,2 Game Boy Advance Buttons Replacement, Prepare your Game Boy for disassembly: 步骤 1 中的图像 2,2
      • Before working on your Game Boy, turn the power switch to the OFF position and unplug any cables.
      • If you have a game cartridge installed, remove it.
      • Since your Game Boy will be laying screen‑side down for most of your repair, consider placing it on a clean cloth for protection.
      询问修复机器人
      添加评论
    1. Game Boy Advance Buttons Replacement, Remove the battery cover: 步骤 2 中的图像 1,3 Game Boy Advance Buttons Replacement, Remove the battery cover: 步骤 2 中的图像 2,3 Game Boy Advance Buttons Replacement, Remove the battery cover: 步骤 2 中的图像 3,3
      • Release the battery cover tab with your finger and swing the cover away from your Game Boy to remove it.
      • During reassembly, insert the tabs on the bottom edge of the cover into their cutouts and press the cover into place.
      询问修复机器人
      添加评论
    2. Game Boy Advance Buttons Replacement, Remove the batteries: 步骤 3 中的图像 1,3 Game Boy Advance Buttons Replacement, Remove the batteries: 步骤 3 中的图像 2,3 Game Boy Advance Buttons Replacement, Remove the batteries: 步骤 3 中的图像 3,3
      • Remove the two AA batteries.
      • If the metal terminals are corroded, follow this guide to clean them.
      • When installing batteries, use the diagram in the battery well to properly orient them.
      询问修复机器人
      添加评论
    1. Game Boy Advance Buttons Replacement, Remove the back shell screws: 步骤 4 中的图像 1,2 Game Boy Advance Buttons Replacement, Remove the back shell screws: 步骤 4 中的图像 2,2
      • Remove the seven screws securing the back shell:
      • Six 9.4 mm‑long tri‑point Y0 screws
      • One 8.5 mm‑long JIS 1 screw
      • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping screws. Push down firmly on the driver and twist slowly.
      询问修复机器人
      添加评论
    2. Game Boy Advance Buttons Replacement, Remove the back shell: 步骤 5 中的图像 1,2 Game Boy Advance Buttons Replacement, Remove the back shell: 步骤 5 中的图像 2,2
      • Lift the back shell straight up and remove it.
      • During reassembly, squeeze the shell firmly around the edges and ensure the shoulder buttons and bumpers are properly seated with no large gaps. Gently test the buttons to make sure everything feels correct.
      询问修复机器人
      添加评论
    1. Game Boy Advance Buttons Replacement, Remove the shoulder buttons: 步骤 6 中的图像 1,3 Game Boy Advance Buttons Replacement, Remove the shoulder buttons: 步骤 6 中的图像 2,3 Game Boy Advance Buttons Replacement, Remove the shoulder buttons: 步骤 6 中的图像 3,3
      • Lift the shoulder buttons (aka L and R buttons) straight up to remove them.
      • During reassembly:
      • Since your Game Boy is laying upside down, the L button will go on your right‑hand side, and the R button will go on your left‑hand side.
      • Slide the buttons into place, making sure the peg on the button goes into its circular cutout and the button itself is over the actual button mechanism.
      • The shoulder buttons will sit on the inside edge of the side bumpers.
      • Gently test the buttons to make sure they feel correct. If they don't, reposition them and make sure the metal arms aren't stuck in a weird position under the board.
      询问修复机器人
      添加评论
    2. Game Boy Advance Buttons Replacement, Remove the side bumpers: 步骤 7 中的图像 1,3 Game Boy Advance Buttons Replacement, Remove the side bumpers: 步骤 7 中的图像 2,3 Game Boy Advance Buttons Replacement, Remove the side bumpers: 步骤 7 中的图像 3,3
      • Remove the side bumpers.
      询问修复机器人
      添加评论
    3. Game Boy Advance Buttons Replacement, Remove the power switch cover: 步骤 8 中的图像 1,2 Game Boy Advance Buttons Replacement, Remove the power switch cover: 步骤 8 中的图像 2,2
      • Remove the power switch cover.
      • During reassembly, make sure the switch cover is properly slotted around the arm on the switch mechanism.
      询问修复机器人
      添加评论
    1. Game Boy Advance Buttons Replacement, Remove the motherboard screws: 步骤 9 中的图像 1,2 Game Boy Advance Buttons Replacement, Remove the motherboard screws: 步骤 9 中的图像 2,2
      • Use a JIS 1 screwdriver to remove the three 7 mm‑long screws securing the motherboard.
      询问修复机器人
      添加评论
    2. Game Boy Advance Buttons Replacement, Reposition the motherboard: 步骤 10 中的图像 1,3 Game Boy Advance Buttons Replacement, Reposition the motherboard: 步骤 10 中的图像 2,3 Game Boy Advance Buttons Replacement, Reposition the motherboard: 步骤 10 中的图像 3,3
      • Be careful not to strain the screen cable that connects the motherboard.
      • Carefully flip the motherboard over the top edge of your Game Boy and rest it on your work surface.
      • During reassembly, make sure the speaker gets correctly slotted into its circular cutout (including a small tab on the bottom) when lowering the motherboard into place.
      询问修复机器人
      添加评论
    3. Game Boy Advance Buttons Replacement, Remove the silicone pads: 步骤 11 中的图像 1,3 Game Boy Advance Buttons Replacement, Remove the silicone pads: 步骤 11 中的图像 2,3 Game Boy Advance Buttons Replacement, Remove the silicone pads: 步骤 11 中的图像 3,3
      • Use tweezers or your fingers to remove the three silicone pads covering the buttons (A and B, the D‑pad, and Start/Select ).
      • If any of the pads are missing, they may be stuck to their corresponding spot on the motherboard.
      • During reassembly, use your fingers to press each pad into place, using the alignment pegs to properly orient them.
      询问修复机器人
      添加评论
    4. Game Boy Advance Buttons Replacement, Remove the action buttons and D‑pad: 步骤 12 中的图像 1,3 Game Boy Advance Buttons Replacement, Remove the action buttons and D‑pad: 步骤 12 中的图像 2,3 Game Boy Advance Buttons Replacement, Remove the action buttons and D‑pad: 步骤 12 中的图像 3,3
      • Use tweezers or your fingers to remove the buttons (A and B as well as the D‑pad).
      • The Start/Select buttons are part of the silicone pad—there are no other buttons to remove.
      • When re‑inserting the action buttons, note that each one is keyed specifically for its recess and proper orientation.
      询问修复机器人
      添加评论
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for troubleshooting help.
取消:我没有完成这个指南。
15等其他人完成本指南。
作者
与
Spencer Day
于09/14/22注册
210,238 声望
创作了1,265篇指南
1指南评论
If you have buttons that don’t respond, you can also just clean the contacts (the round black ones and the gold ones on the board) with alcohol and a Q-tip. After that, I coated the contacts with some contact spray, also with Q-tip. All buttons are working again.
Simon - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 94
过去 30 天: 367
总计 31,050
