跳转到主内容
Game Boy Advance Back Shell Replacement
你所需要的
  1. Game Boy Advance Back Shell Replacement, Prepare your Game Boy for disassembly: 步骤 1 中的图像 1,2 Game Boy Advance Back Shell Replacement, Prepare your Game Boy for disassembly: 步骤 1 中的图像 2,2
    • Before working on your Game Boy, turn the power switch to the OFF position and unplug any cables.
    • If you have a game cartridge installed, remove it.
    • Since your Game Boy will be laying screen‑side down for most of your repair, consider placing it on a clean cloth for protection.
  2. Game Boy Advance Back Shell Replacement, Remove the battery cover: 步骤 2 中的图像 1,3 Game Boy Advance Back Shell Replacement, Remove the battery cover: 步骤 2 中的图像 2,3 Game Boy Advance Back Shell Replacement, Remove the battery cover: 步骤 2 中的图像 3,3
    • Release the battery cover tab with your finger and swing the cover away from your Game Boy to remove it.
    • During reassembly, insert the tabs on the bottom edge of the cover into their cutouts and press the cover into place.
  3. Game Boy Advance Back Shell Replacement, Remove the batteries: 步骤 3 中的图像 1,3 Game Boy Advance Back Shell Replacement, Remove the batteries: 步骤 3 中的图像 2,3 Game Boy Advance Back Shell Replacement, Remove the batteries: 步骤 3 中的图像 3,3
    • Remove the two AA batteries.
    • If the metal terminals are corroded, follow this guide to clean them.
    • When installing batteries, use the diagram in the battery well to properly orient them.
  4. Game Boy Advance Back Shell Replacement, Remove the back shell screws: 步骤 4 中的图像 1,2 Game Boy Advance Back Shell Replacement, Remove the back shell screws: 步骤 4 中的图像 2,2
    • Remove the seven screws securing the back shell:
    • Six 9.4 mm‑long tri‑point Y0 screws
    • One 8.5 mm‑long JIS 1 screw
    • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping screws. Push down firmly on the driver and twist slowly.
  5. Game Boy Advance Back Shell Replacement, Remove the back shell: 步骤 5 中的图像 1,2 Game Boy Advance Back Shell Replacement, Remove the back shell: 步骤 5 中的图像 2,2
    • Lift the back shell straight up and remove it.
    • During reassembly, squeeze the shell firmly around the edges and ensure the shoulder buttons and bumpers are properly seated with no large gaps. Gently test the buttons to make sure everything feels correct.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for troubleshooting help.
5等其他人完成本指南。
Spencer Day
于09/14/22注册
153,502 声望
创作了1,024篇指南
2指南评论
Seeing the GBA-SP guide, could information here be added so we know which mm triwing screws the regular GBA backpanel uses?
Renzo Guichelaar - 回复
We've updated the guide, and it now includes the screw measurements.
Spencer Day -
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 21
过去 30 天: 127
总计 12,436
