跳转到主内容
加入维修社区 - 创建账户
GPD MicroPC
你所需要的
    1. GPD MicroPC, Prep: 步骤 1 中的图像 1,1
      • Make sure device is fully powered off, remove any connected devices and micro SD cards.
      • Based on the nature of your need, backup any sensitive documents or files before starting.
      询问修复机器人
      添加评论
    2. GPD MicroPC: 步骤 2 中的图像 1,1
      在这个步骤中使用的工具:
      Phillips #00 Screwdriver
      $5.49
      • Remove 5 screws using a Phillips #00 Screwdriver
      • The opening for the screws is quite small, under 3mm. Ensure your tool has the clearance to fit.
      询问修复机器人
      添加评论
    3. GPD MicroPC: 步骤 3 中的图像 1,3 GPD MicroPC: 步骤 3 中的图像 2,3 GPD MicroPC: 步骤 3 中的图像 3,3
      在这个步骤中使用的工具:
      Spudger
      $3.99
      • Using a prying tool like a Spudger, pry open the bottom half.
      • There are some locking tabs on both the bottom half and the main body. There is a specific tab near the COM port which makes it tougher to pry open. It may be easier to pry from the LAN port area instead. Continue from that spot along the side towards the front audio jack and keep going until the bottom half easily comes off.
      • Remember to take out the MicroSD before continuing further
      询问修复机器人
      添加评论
    4. GPD MicroPC: 步骤 4 中的图像 1,2 GPD MicroPC: 步骤 4 中的图像 2,2
      • The main components are now exposed.
      • The yellow boxes are where the locking tabs are located. The orange box highlights the COM specific tab mentioned earlier.
      • To reassemble, follow these instructions in reverse.
      • For an easier time during reassembly, line up the COM tab first and ensure that it is seated properly. If that tab isn't seated right, the bottom half may not come together properly leading to potential damages.
      询问修复机器人
      添加评论
终点
取消:我没有完成这个指南。
4等其他人完成本指南。
Mike
于11/23/18注册
274 声望
撰写一个指南
2指南评论
Bonjour ,je pourrais avoir la référence de la batterie s'il vous plait merci Voici mon numéro 06 65 55 57 51
mbc - 回复 分享
Information from OEM rechargeable Li-polymer battery label:
Model: 4841105-2S
Voltage: 7.6V
3100mAh 23.56Wh 2ICP5/41/105
Charge voltage:8.7V
"+" PIN1, PIN8 ; "-" PIN4, PIN5
Standard: GB31241-2014
Mfr: DONGGUAN GANFENG ELECTRONIC CO .,LTD
Apprx Size: 11cm x 4cm x 5mm*2 (there are two batteries stacked on top of each other)
Mike - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 64
总计 3,283
