跳转到主内容
加入维修社区 - 创建账户
GE Washing Machine Agitator Replacement
视频指南
本指南转录自 YouTube 视频。
你所需要的
      • Raise the lid to give full access to the agitator assembly.
      询问修复机器人
      添加评论
      • Look for the small round hole located at the very bottom of the agitator skirt.
      • This hole is the only place where a tool can lock the agitator for removal.
      询问修复机器人
      添加评论
      • Feel around the agitator base until you find the raised nipple on the washer plate.
      • Rotate the agitator until its hole lines up directly over the nipple.
      • Removal will not work unless these two features line up exactly.
      询问修复机器人
      添加评论
      • Insert a Phillips screwdriver through the hole and press it in until it bottoms out.
      • Push the screwdriver in deeply so it fully engages the mechanism.
      询问修复机器人
      添加评论
      • Have a helper hold the washer tub steady so it cannot rotate while you twist the agitator.
      • If working solo, brace the tub with your free hand while keeping the screwdriver seated.
      询问修复机器人
      添加评论
      • Grip the agitator housing and turn it clockwise until it breaks free from the drive tabs.
      • Lift the agitator straight up and out of the tub once it releases.
      询问修复机器人
      添加评论
      • If you need hub access, remove the central 7⁄16-inch bolt with a socket wrench and lift off the plate.
      询问修复机器人
      添加评论
      • Align the four slots on the agitator base with the four plastic retention pieces on the washer plate.
      • Lower the agitator onto the tabs until it sits flush on the plate.
      询问修复机器人
      添加评论
      • Twist the agitator clockwise until it snaps and will not rotate freely.
      • Rock the agitator back and forth to confirm it is fully seated.
      询问修复机器人
      添加评论
      • Press the fabric-softener dispenser cap back onto the agitator top.
      询问修复机器人
      添加评论
结论
Repair didn't go as planned? Ask our Answers community for help.
取消:我没有完成这个指南。
Ben Schlichter
于01/21/25注册
7,128 声望
创作了224篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 48
过去 30 天: 252
总计 1,106
