跳转到主内容
GE A1050 LCD Replacement
你所需要的
  1. GE A1050 LCD Replacement, LCD: 步骤 1 中的图像 1,3 GE A1050 LCD Replacement, LCD: 步骤 1 中的图像 2,3 GE A1050 LCD Replacement, LCD: 步骤 1 中的图像 3,3
    • Remove the batteries, hand strap, and memory card if so equipped.
    • Remove the two Phillips screws from the bottom.
    • Remove the two Phillips screws from the left side.
  2. GE A1050 LCD Replacement: 步骤 2 中的图像 1,3 GE A1050 LCD Replacement: 步骤 2 中的图像 2,3 GE A1050 LCD Replacement: 步骤 2 中的图像 3,3
    • Remove the two screws from the right side.
    • The two screws from the left side are shorter than the ones from the right. Keep those separated.
    • Start splitting the case from the battery compartment to the sides. No special tool is needed to split the case.
  3. GE A1050 LCD Replacement: 步骤 3 中的图像 1,3 GE A1050 LCD Replacement: 步骤 3 中的图像 2,3 GE A1050 LCD Replacement: 步骤 3 中的图像 3,3
    • Do not remove the back side of the case, just flip it over. The speaker is connected by wires to the main body, but positioned in the back case.
    • Flip the LCD to the bottom. You can not yet remove it, because it is still attached to the board.
    • The LCD cable is held into the connector via some compression clips. Move both ends carefully away from the connector, toward the LCD.
    • The clips only move about an 1/8 of an inch. Be careful not to use too much force.
  4. GE A1050 LCD Replacement: 步骤 4 中的图像 1,1
    • After exchanging the LCD for a new one, and after reassembling your camera, you should have a working LCD.
结论
另外一个人完成了本指南。
oldturkey03
于09/29/10注册
791,325 声望
创作了119篇指南
团队
Global Fixers Global Fixers 的会员
Community
35 名成员
创作了603篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 18
总计 1,802
