跳转到主内容
加入维修社区 - 创建账户
GD Midea FT30-3D Power/Speed Switch Replacement
你所需要的
  1. GD Midea FT30-3D Power/Speed Switch Replacement, Bottom Base: 步骤 1 中的图像 1,1
    • Locate and remove the 14.5 mm Phillips #1 screw on the bottom of the fan base.
    询问修复机器人
    添加评论
  2. GD Midea FT30-3D Power/Speed Switch Replacement: 步骤 2 中的图像 1,2 GD Midea FT30-3D Power/Speed Switch Replacement: 步骤 2 中的图像 2,2
    • Locate the gray base support release tabs found on either side pictured in the first image.
    • There are release tabs on each side of the base.
    • Press both release tabs in with the tip of your fingers and pull the gray base support until the tabs are cleared.
    询问修复机器人
    添加评论
  3. GD Midea FT30-3D Power/Speed Switch Replacement: 步骤 3 中的图像 1,1
    • Continue removing the gray base support by pressing your thumb into the circular opening in the base and pulling with your figures on the back side.
    • Notice that on the internal front tip of the base there is a tab. Because of this tab the back end will pivot off at that point.
    询问修复机器人
    添加评论
  4. GD Midea FT30-3D Power/Speed Switch Replacement: 步骤 4 中的图像 1,1
    • After the base has separated more it will be easy to fully remove it. Continue pulling the back edge of the gray base support, rotating it around the front tab until it comes off completely.
    询问修复机器人
    添加评论
  5. GD Midea FT30-3D Power/Speed Switch Replacement: 步骤 5 中的图像 1,1
    • Remove the following five 14.5 mm Phillips #1 screws found on the bottom.
    • All of the screws are recessed by 17.5 mm, so ensure your screwdriver can reach that far.
    询问修复机器人
    添加评论
  6. GD Midea FT30-3D Power/Speed Switch Replacement: 步骤 6 中的图像 1,1
    • Once all five screws have been removed the base cover should fall right off with out any effort.
    • When putting the base cover back on; be careful to make sure that none of the wires are pinched.
    询问修复机器人
    添加评论
  7. GD Midea FT30-3D Power/Speed Switch Replacement, Power/Speed Switch: 步骤 7 中的图像 1,1
    • Remove the two 10 mm Phillips #1 screws found connecting the switch to the case.
    • Notice the AC power cord line (white wire) goes into the switch under the [Off] button
    询问修复机器人
    添加评论
  8. GD Midea FT30-3D Power/Speed Switch Replacement: 步骤 8 中的图像 1,1
    • Take the 1.5 mm Flathead Screwdriver, or any thin elongated tool that fits into the semi-circular holes along side the wires. Press into the hole gently to release the grip on the wires.
    • The wires should release with ease if done properly.
    • When reassembling; skip this step.
    询问修复机器人
    添加评论
  9. GD Midea FT30-3D Power/Speed Switch Replacement: 步骤 9 中的图像 1,1
    • Take the new switch, and simply push the wiring into the correct holes:
    • AC Power Cord (white wire)
    • Low speed (gray wire)
    • Medium speed (orange wire)
    • High speed (red wire)
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Alan Su
于10/03/12注册
846 声望
创作了6篇指南
团队
Cal Poly, Team 24-28, Regan Fall 2012 Cal Poly, Team 24-28, Regan Fall 2012 的会员
CPSU-REGAN-F12S24G28
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 56
总计 4,300
