跳转到主内容
加入维修社区 - 创建账户
G'z One Boulder Inside Screen Cover Replacement
你所需要的
    1. G'z One Boulder Inside Screen Cover Replacement, Inside Screen Cover: 步骤 1 中的图像 1,1
      • There are 4 black screws that need to be removed on the top of the lid. A 1.5mm flathead screwdriver will work on the star shaped screw heads.
      • Make note that two of the screws closest to the hinge are longer than the other two.
      询问修复机器人
      添加评论
    2. G'z One Boulder Inside Screen Cover Replacement: 步骤 2 中的图像 1,2 G'z One Boulder Inside Screen Cover Replacement: 步骤 2 中的图像 2,2
      • Remove the two side screws.
      • When reassembling you may need to press the front and back of the lid together when inserting these side screws so that the holes align.
      询问修复机器人
      添加评论
    3. G'z One Boulder Inside Screen Cover Replacement: 步骤 3 中的图像 1,2 G'z One Boulder Inside Screen Cover Replacement: 步骤 3 中的图像 2,2
      • Use a plastic opening tool to remove the screen cover from the rest of the lid.
      询问修复机器人
      添加评论
    4. G'z One Boulder Inside Screen Cover Replacement: 步骤 4 中的图像 1,2 G'z One Boulder Inside Screen Cover Replacement: 步骤 4 中的图像 2,2
      • Your phone should look like the picture to the left.
      • If reassembling from a previous step make sure the ribbon cable is properly situated before securing the front cover.
      询问修复机器人
      添加评论
结论
To disassemble your device, follow these instructions in reverse order.
取消:我没有完成这个指南。
团队
Clemson, Team 13-3, Benson Spring 2013 Clemson, Team 13-3, Benson Spring 2013 的会员
CLEM-BENSON-S13S13G3
3 名成员
创作了70篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 26
总计 770
