跳转到主内容
加入维修社区 - 创建账户
Fused LED Light Replacement
你所需要的
    1. Fused LED Light Replacement, Fused LED Light: 步骤 1 中的图像 1,2 Fused LED Light Replacement, Fused LED Light: 步骤 1 中的图像 2,2
      • Remove the upper semi-sphere diffuser by twisting or applying some heat with a heat gun or dryer to soften the adhesive.
      添加评论
    2. Fused LED Light Replacement: 步骤 2 中的图像 1,3 Fused LED Light Replacement: 步骤 2 中的图像 2,3 Fused LED Light Replacement: 步骤 2 中的图像 3,3
      • Use a battery or a cell with connecting wires and apply them to the exposed solder ends on each LED.
      • The LED which doesn't lights up is detected as the faulty LED.
      添加评论
    3. Fused LED Light Replacement: 步骤 3 中的图像 1,1
      • Using a knife or screwdriver, remove the faulty LED.
      • We need to replace it with a similar LED or a resistor.
      • Connecting the terminals directly can result in an increased current and multiple LED failure.
      询问修复机器人
      添加评论
    4. Fused LED Light Replacement: 步骤 4 中的图像 1,2 Fused LED Light Replacement: 步骤 4 中的图像 2,2
      • Using the soldering iron solder an LED or a 100Ω (2W or 5W) resistor into the faulty LED space.
      添加评论
    5. Fused LED Light Replacement: 步骤 5 中的图像 1,1
      • Connect the bulb to a power source to detect if it's working.
      询问修复机器人
      添加评论
    6. Fused LED Light Replacement: 步骤 6 中的图像 1,2 Fused LED Light Replacement: 步骤 6 中的图像 2,2
      • Finally, twist the light-diffusing dome back on the light bulb.
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
1指南评论
I have a large LED bulb with 8 banks of LEDs. The bulb would flicker at times then stay illuminated for a period. After a short time doing this it would completely stop then come back on. It finally stopped working at all. I engineered myself a couple leads from some old multimeter leads I had collecting dusk. I attached those to a fresh 9v battery then checked each bank of LED. All illuminate as quickly as I touch the leads to the first LED in each bank. What’s the issues with this bulb? It’s not due to a bad LED and breaking the continuity. I also prior to testing with the battery went through each bank getting a solid tone so there’s no loss of power from ATo Z. I’m open to suggestions based on your experience tackling this issue. It’s my first rodeo with the LED bulb. Thanks for your help.
Farron - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 34
过去 30 天: 138
总计 10,100
