跳转到主内容
加入维修社区 - 创建账户
Function Key Motherboard
你所需要的
    1. Function Key Motherboard, Front and Back Covers: 步骤 1 中的图像 1,3 Function Key Motherboard, Front and Back Covers: 步骤 1 中的图像 2,3 Function Key Motherboard, Front and Back Covers: 步骤 1 中的图像 3,3
      • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
      • There are 2 screws on the left side (when looking at the front of the camera).
      • There are 3 screws on the bottom
      • There is 1 screw on the right side
      询问修复机器人
      添加评论
    2. Function Key Motherboard: 步骤 2 中的图像 1,1
      • Turn to the bottom of the camera.
      • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
      询问修复机器人
      添加评论
    3. Function Key Motherboard: 步骤 3 中的图像 1,1
      • This is what the SD card/battery compartment looks like when opened.
      • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
      询问修复机器人
      添加评论
    4. Function Key Motherboard: 步骤 4 中的图像 1,2 Function Key Motherboard: 步骤 4 中的图像 2,2
      • Gently remove the front cover away from the camera body.
      • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
      询问修复机器人
      添加评论
    5. Function Key Motherboard: 步骤 5 中的图像 1,1
      • The camera should look like this once the front cover is removed.
      询问修复机器人
      添加评论
    6. Function Key Motherboard: 步骤 6 中的图像 1,3 Function Key Motherboard: 步骤 6 中的图像 2,3 Function Key Motherboard: 步骤 6 中的图像 3,3
      在这个步骤中使用的工具:
      • Start from the battery compartment and remove the back cover.
      • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
      • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
      询问修复机器人
      添加评论
    7. Function Key Motherboard: 步骤 7 中的图像 1,1
      • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
      询问修复机器人
      添加评论
    1. Function Key Motherboard, Function Key Motherboard: 步骤 8 中的图像 1,3 Function Key Motherboard, Function Key Motherboard: 步骤 8 中的图像 2,3 Function Key Motherboard, Function Key Motherboard: 步骤 8 中的图像 3,3
      • Remove 2 4.35mm phillips head screws from around the LCD screen using a #00 phillips head screwdriver.
      • Caution: Do not tug on the LCD screen because this could tear the ribbon connecting the LCD screen to the body of the camera.
      • Loosen the black ribbon clamp using an iPod opening tool
      • Release the LCD screen by removing the ribbon from the body of the camera.
      询问修复机器人
      添加评论
    2. Function Key Motherboard: 步骤 9 中的图像 1,2 Function Key Motherboard: 步骤 9 中的图像 2,2
      • Unscrew 2 3.35mm phillips head screw from the face of the function key motherboard using a #00 phillips head screwdriver.
      • Caution: Do not tug on the motherboard because this will tear the ribbon connecting the motherboard to the body of the camera.
      询问修复机器人
      添加评论
    3. Function Key Motherboard: 步骤 10 中的图像 1,3 Function Key Motherboard: 步骤 10 中的图像 2,3 Function Key Motherboard: 步骤 10 中的图像 3,3
      在这个步骤中使用的工具:
      • Release the black ribbon clamp attached to the back of the motherboard using an iPod opening tool to lift the clamp.
      • Remove the ribbon connecting the function key motherboard from the body of the camera using tweezers.
      • The function key motherboard has the SD card reader attached to the back. The motherboard and SD card combination should be replaced.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team 8-6, Regan Spring 2011 Cal Poly, Team 8-6, Regan Spring 2011 的会员
CPSU-REGAN-S11S8G6
4 名成员
创作了23篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 37
总计 3,784
