跳转到主内容
加入维修社区 - 创建账户
Fujtsu Lifebook Model A6110 Keyboard Replacement
你所需要的
    1. Fujtsu Lifebook Model A6110 Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 Fujtsu Lifebook Model A6110 Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
      • The computer should be fully turned off and disconnected from the power source.
      • Before handling electronic components, you should ground yourself. This will prevent damage to the components from a static charge. You can do this by touching any metal object.
      • Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
      询问修复机器人
      添加评论
    2. Fujtsu Lifebook Model A6110 Keyboard Replacement: 步骤 2 中的图像 1,1
      • To remove the battery, place your fingers underneath the two clips and simultaneously lift them up while pulling the cover towards you.
      询问修复机器人
      添加评论
    1. Fujtsu Lifebook Model A6110 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,3 Fujtsu Lifebook Model A6110 Keyboard Replacement, Keyboard: 步骤 3 中的图像 2,3 Fujtsu Lifebook Model A6110 Keyboard Replacement, Keyboard: 步骤 3 中的图像 3,3
      • Position the laptop like you would if you were to use it. Open the screen to a 180 degrees angle. The screen and the keyboard needs to face up before proceeding.
      • Using a flat edge of the plastic spudger, gently lift the piece of plastic located in the red square. Carefully insert the spudger between the inner edge marked by the arrow.
      询问修复机器人
      添加评论
    2. Fujtsu Lifebook Model A6110 Keyboard Replacement: 步骤 4 中的图像 1,3 Fujtsu Lifebook Model A6110 Keyboard Replacement: 步骤 4 中的图像 2,3 Fujtsu Lifebook Model A6110 Keyboard Replacement: 步骤 4 中的图像 3,3
      • With a Phillips #1 screwdriver, unscrew the four-six mm screws that were hidden under the plastic piece you removed.
      询问修复机器人
      添加评论
    3. Fujtsu Lifebook Model A6110 Keyboard Replacement: 步骤 5 中的图像 1,3 Fujtsu Lifebook Model A6110 Keyboard Replacement: 步骤 5 中的图像 2,3 Fujtsu Lifebook Model A6110 Keyboard Replacement: 步骤 5 中的图像 3,3
      • Lift up on the inner edges of the hinges for the screen. This will detach the face-plate from the computer. Use a spudger to make this process easier.
      • There is a ribbon underneath this panel that attaches to the motherboard. Be careful to not rip this ribbon.
      • The ribbon is located in the top left-hand corner and needs to carefully disconnected from the motherboard, as shown in the next step.
      询问修复机器人
      添加评论
    4. Fujtsu Lifebook Model A6110 Keyboard Replacement: 步骤 6 中的图像 1,2 Fujtsu Lifebook Model A6110 Keyboard Replacement: 步骤 6 中的图像 2,2
      • Detach the ribbon from the motherboard, which will allow you to finish removing the face-plate from the computer.
      • To detach the ribbon, grip the ribbon at the base that is attached to the motherboard, which is the large green circuit-board in the body of the computer.
      • When reassembling the computer, make sure to reconnect the ribbons.
      询问修复机器人
      添加评论
    5. Fujtsu Lifebook Model A6110 Keyboard Replacement: 步骤 7 中的图像 1,2 Fujtsu Lifebook Model A6110 Keyboard Replacement: 步骤 7 中的图像 2,2
      • There is another ribbon connecting the keyboard to the motherboard. Be careful not to rip it
      • The keyboard is now free. Lift up on the keyboard.
      询问修复机器人
      添加评论
    6. Fujtsu Lifebook Model A6110 Keyboard Replacement: 步骤 8 中的图像 1,1
      • This ribbon may be difficult to remove, so be careful in pulling it. You could accidentally break it.
      • Detatch the ribbon from the motherboard
      • When reassembling the computer, make sure to reconnect this ribbon.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Cody Moniz
于10/19/16注册
422 声望
创作了4篇指南
团队
UMass Dartmouth, Team 3-2, Isaacson Fall 2016 UMass Dartmouth, Team 3-2, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S3G2
3 名成员
创作了45篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 30
总计 1,061
