跳转到主内容
加入维修社区 - 创建账户
Fujifilm X30 Lens Replacement
你所需要的
    1. Fujifilm X30 Lens Replacement, Battery: 步骤 1 中的图像 1,2 Fujifilm X30 Lens Replacement, Battery: 步骤 1 中的图像 2,2
      • Turn the camera upside down.
      • Place your thumb on the switch, and slide it towards the center of the camera.
      • The compartment will pop open.
      询问修复机器人
      添加评论
    2. Fujifilm X30 Lens Replacement: 步骤 2 中的图像 1,1
      • Once you have the battery compartment open, slide the orange tab away from the battery until it ejects.
      询问修复机器人
      添加评论
    3. Fujifilm X30 Lens Replacement: 步骤 3 中的图像 1,1
      • Pull the battery out.
      询问修复机器人
      添加评论
    1. Fujifilm X30 Lens Replacement, Lens: 步骤 4 中的图像 1,3 Fujifilm X30 Lens Replacement, Lens: 步骤 4 中的图像 2,3 Fujifilm X30 Lens Replacement, Lens: 步骤 4 中的图像 3,3
      • Begin by removing the outside screws using a Phillips #000 Screwdriver:
      • Remove the three 3.6 mm silver screws located on the bottom of the camera.
      • Remove all four of the 4.7 mm screws from the sides of the camera.
      询问修复机器人
      添加评论
    2. Fujifilm X30 Lens Replacement: 步骤 5 中的图像 1,2 Fujifilm X30 Lens Replacement: 步骤 5 中的图像 2,2
      • Remove all screws listed below using a Phillips #000 Screwdriver:
      • Lift up the screen and remove the two 4.5 mm screws located in the bottom corners.
      • Remove the 4.0 mm screw that is located behind the screen and directly under the eye piece.
      询问修复机器人
      添加评论
    3. Fujifilm X30 Lens Replacement: 步骤 6 中的图像 1,1
      • Carefully remove the bottom piece of the camera.
      询问修复机器人
      添加评论
    4. Fujifilm X30 Lens Replacement: 步骤 7 中的图像 1,1
      • Do not pull hard when removing the backing because it could rip the orange strip attached to the motherboard.
      • Gently pull off the back of the camera from the left side so that it is partially open.
      • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it
      • Refer to the next step to see pictures of how to properly use the spudger when removing a strip.
      询问修复机器人
      添加评论
    5. Fujifilm X30 Lens Replacement: 步骤 8 中的图像 1,3 Fujifilm X30 Lens Replacement: 步骤 8 中的图像 2,3 Fujifilm X30 Lens Replacement: 步骤 8 中的图像 3,3
      • For all five indicated orange strips:
      • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it.
      询问修复机器人
      添加评论
    6. Fujifilm X30 Lens Replacement: 步骤 9 中的图像 1,1
      • For the final orange strip located behind the top strip:
      询问修复机器人
      添加评论
    7. Fujifilm X30 Lens Replacement: 步骤 10 中的图像 1,3 Fujifilm X30 Lens Replacement: 步骤 10 中的图像 2,3 Fujifilm X30 Lens Replacement: 步骤 10 中的图像 3,3
      • Remove the two 3.4 mm screws at the bottom of the silver plate.
      • Peel back the clear strip to reveal a 2.8 mm screw on the left of the silver plate and remove it.
      • Peel back the copper plate.
      添加评论
    8. Fujifilm X30 Lens Replacement: 步骤 11 中的图像 1,1
      • Remove the three 2.6 mm screws located in the top two corners and the bottom right corner of the motherboard using a Phillips #000 Screwdriver.
      • Lift the motherboard so it is out of your way to remove the lens.
      • You do not need to desolder the motherboard to reach the lens.
      询问修复机器人
      添加评论
    9. Fujifilm X30 Lens Replacement: 步骤 12 中的图像 1,1
      • Remove the four 4.4 mm silver screws at the corners of the lens using a Phillips #000 Screwdriver.
      询问修复机器人
      添加评论
    10. Fujifilm X30 Lens Replacement: 步骤 13 中的图像 1,2 Fujifilm X30 Lens Replacement: 步骤 13 中的图像 2,2
      • Pull the lens down so it can clear the silver tab.
      • Then push the lens with your index fingers from the front of the camera until it is removed.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
Haley Moss
于01/11/16注册
370 声望
撰写一个指南
团队
Cal Poly, Team 70-3, Forte Winter 2016 Cal Poly, Team 70-3, Forte Winter 2016 的会员
CPSU-FORTE-W16S70G3
5 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 72
总计 6,175
