此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
在这个步骤中使用的工具:Mako Driver Kit - 64 Precision Bits$39.95
这是由一家日本相机制造商生产的相机。日本相机行业非常喜欢使用 JIS(日本工业标准)螺丝。
不要试图使用你的 Phillips 螺丝刀套装。虽然 PH#00 螺丝刀可以与 JIS#00 螺丝通用,但它们并不完全匹配。使用 Phillips 螺丝刀会加剧 JIS 螺丝头的磨损,并导致螺丝过早滑丝。
在本次拆解过程中,请同时准备好 JIS#00 和 JIS#000 螺丝刀。幸运的是,iFixit 64 位螺丝刀套装中包含了这两种规格的批头。
若要重新安装相机的镜头,请按照上述步骤的相反顺序进行操作。
4等其他人完成本指南。
3指南评论
can you tel us how to put it back together.
I no longer have the Fuji x100T, but it may be possible to disassemble the lens from the front. Many modern cameras have a glued-on beauty ring / lens nameplate ring on the front of the lens. The ring I am specifically referring to is the “Fujinon Aspherical Lens Super EBC f23mm 1:2.” Nameplate rings are traditionally used to hide screws or a circular threaded ring which holds the lens together. Here is an example, specifically at 9:46min mark http://www.youtube.com/watch?v=yRPwEsAYz...
I would suggest watching more of mikeno62’s lens repair videos to get familiar with lens disassembly. I don’t have a service manual for this camera, but there may be screws hidden behind the nameplate ring.
Make sure to take your time with the lens disassembly. Be careful of the hardness of the tool you use. Plastic (mohs hardness of 2) wont scratch glass (mohs hardness of 5.5) and neither will rubber. Make sure to document the disassembly so you don’t reassemble the lens wrong. Work on a large empty table, you’ll need it! Good luck!
